Thread started 14 Sep 2014 (Sunday) 20:39
Anyone ever had trouble with their lexar 3.0 USB
tennfan1125
Sep 14, 2014 20:39 |  #1
Hello, so I recently brought a lexar USB 3.0 card reader. But I'm having trouble getting it to read my memory card. Sometimes it will but most times it won't. I'm not sure what the problem is. I don't have the booklet that comes with it. So I can't really read up on it. Ever have problems like this. I'm hoping someone can help me...
canon 30d, canon 1d mkIII, 50mm 1.8, 18-55mm, canon 1.4 extender, canon 400mm f2.8 IS, canon 70-200 f2.8 IS II, Canon 16-35mm f2.8,Pocket Wizards,430 ex II, 580 ex II, Canon 430 EX, sigma SA-9, 70-300 5.6, 28-80mm(which I NEVER use)
AbPho
Sep 14, 2014 21:04 |  #2
Have you tried a different USB cable?
I'm in Canada. Isn't that weird!
sonnyc
Joined Jun 2005
Sep 15, 2014 01:11 |  #3
See if you can flash the firmware.
Sonny
tennfan1125
Sep 15, 2014 06:33 |  #4
I've tried 2 different cables, I haven't tried anything with the firmware. Not too sure how it's done
lsuber
Sep 15, 2014 09:14 |  #5
Is there any chance you're on a Mac, running Mavericks? Have seen some posts out there about this very issue with several card readers, and I had it myself. I have a SIIG one that wouldn't connect either, after giving years of trouble-free service. Updated the firmware (which you have to get from Sandisk, but they use the same chipset in both readers), and it's worked without trouble since doing that.
Canon 5D Mark II | 28-70mm f/2.8L USM | Σ 70-200mm f/2.8 APO EX DG HSM OS | 85mm f/1.2L USM | Σ 50mm f/1.4 EX DG HSM | 50mm f/2.5 Compact Macro | LR5 | PS CS5
tennfan1125
Sep 15, 2014 09:16 |  #6
I do have a Mac....I'll try to update my firmware
sonnyc
Joined Jun 2005
Sep 15, 2014 10:52 |  #7
You can download here and run. I had to do the same for my Kingston on my Mac.
http://www.lexar.com/d​ownloads (external link)
Sonny
tennfan1125
Sep 15, 2014 14:24 |  #8
Thanks so much, I think that was the problem. Thanks again
SirStuey
Sep 16, 2014 20:54 |  #9
SD card or CF? I have the same reader, and it works fine with CF but freezes up with certain Sandisk Extreme SD cards.
DisrupTer911
Sep 19, 2014 09:49 |  #10
Do all your cards give you issues like this or just one in particular?
www.vividemotionphotograph​y.comexternal link
lsuber
Sep 20, 2014 07:14 |  #11
I don't know about the OP's issue, but mine was with CF cards only. The same reader would read SD cards fine. Reads CF cards after the firmware update.
2,901 views & 0 likes for this thread, 6 members have posted to it.
1699 guests, 140 members online
