Thread started 19 Feb 2006 (Sunday) 13:37
Home made light tent
DavidEB
Feb 19, 2006 13:37 |  #1
There have been a few posts recently about light tents and product shots, so I thought I'd share my method.
The light tent is a frame made of PVC pipe and a cover made from a cheap white bed sheet. The corners of the frame are glued at the T pieces, and the 90-degree angle piece is glued to the leg, but the legs are loose, just press-fit in, which lets the whole thing fold up. If you make one yourself, be sure to get the T pieces aligned square to each other.
Here you see the corner, and how the frame is set up, with the tripod in position for later. I clip posterboard onto the top of the frame to make a nice background.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
DavidEB
Feb 19, 2006 13:39 |  #2
Here's how the tent is stored. The legs fold up, and the whole thing lies flat under a bed.
the frame is 30 x 30 x 30 inches, approximately, and I used 2 lengths of PVC pipe to make it.
David
DavidEB
Feb 19, 2006 13:43 as a reply to  @ DavidEB's post |  #3
Here the frame is covered with the bedsheet. I sewed the corners of the sheet together to make a snug fit, and cut small windows into the sides. In the upper right corner you can see large paper clips which hold the background posterboard.
If you've seen some of my other posts, you might recognize my son and my dog helping me out.
David
md_129
Joined Nov 2005
Feb 19, 2006 13:46 |  #4
great post, I am sure this will help alot of people.
Mike
Current Projects:
http://webdoctus.com/ (external link)
DavidEB
Feb 19, 2006 13:48 as a reply to  @ DavidEB's post |  #5
I cut windows into the covering sheet to shoot through. The windows are covered with flaps of the same fabric, so that reflections of the windows don't show up in the final picture. There are a total of 3 windows at different heights, allowing shots of different perspective.
It helps to use a tripod that lets you position the camera right up against the openning. Seen here is my gitzo explorer, which is tripod heaven.
David
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Feb 19, 2006 13:50 |  #6
Great idea. I was actually considering to build a small box out of word but this is much better (easier too).
Do You have any lights inside or do You just use flash?
EDITING OF MY PHOTOS IS NOT ALLOWED
DavidEB
Feb 19, 2006 13:51 as a reply to  @ DavidEB's post |  #7
Here are four shots of my wife's pottery. Pottery is particularly tough because the glaze is highly reflective and any uneveness shows up as glare or hot-spots on the final photo.
I shoot using custom white balance (take test shot of the white background within the tent), and in this case natural light. Position the tent so that the amount of light falling on the top, sides, and front is even. Sometime's I've added small desktop lamps as needed. Exposures are ISO100, f22, 2 to 3 seconds. I use mirror lockup and a cable release. Because I can get the exposure and white balance exactly right, I don't use RAW -- jpg comes out just fine. These are with a 1D...N and a tamron 28-75. The zoom helps to properly frame objects of different sizes.
David
DavidEB
Feb 19, 2006 13:59 |  #8
Hope this is helpful. The tent cost about $5-10 for the PVC stuff and the bedsheet was lying around the house. My wife's pottery is beautiful and is for sale. Happy shooting.
David
mson
Joined Mar 2004
Feb 19, 2006 14:03 |  #9
Nice job. The results are fantastic.
--Mike--
Critique with ruthless compassion
Canon 20D | 24-70 f/2.8L | 70-200 f/2.8L IS | Canon 50mm f/1.8 | 430EX | 055XPROB/488RC2
Lotto
Feb 19, 2006 17:24 as a reply to  @ mson's post |  #10
Great job! I like it how you made leggs fold up, very portable.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
blue_max
May 28, 2006 05:25 as a reply to  @ Lotto's post |  #11
As I'm in the market for a larger litecube (which work very well, I might add), I am now in need of a larger one - I have only borrowed the 2 foot version.
Trying to get hold of the 4ft one in a hurry is a problem as is the cost!
I am going to try your suggestions, which seem simple but brilliant. :lol:
Many thanks for sharing your inspiration.
Graham
Lamb dressed as mutton.
Nidz
May 28, 2006 06:22 |  #12
I also this weekend made a small light tent. This time I didn't use white material (which I wish I had because it softens the light very well). I used cardboard. The thick kind with the corigated inside which holds's it's shape. I saw somebody use it on another website that I found instructions on.
Small pic:
HTTP response: 403 | MIME changed to 'text/html'
I've been messing around with a home light setup. This is a test shot from today. This is with direct light, no softening sheets at all. You can see 4 light sources if you look carefully. I haven't made any softener sheets yet. The following shots were taken with my EF35-135 Lens which is over 12 years old. Touched up in PS and white balance slightly adjusted. That's about all I did. PS: The picture has not been sharpened at all. Taken in RAW and just tweaked.
But well done on your tent there. It's good to see people being inventive and comming up with good budget solutions for what can be a very expensive hobby.
Stop or I'll Shoot!
10 Years on POTN Forums!
Canon 350D | 70-200f/4L | ef35-105mm | ef100-300mm | 50mm f1.8 etc..
Some of my Photos (external link)
SuzyView
May 28, 2006 06:28 |  #13
Now that is a helpful thread right here. I'm going to Home Depot as soon as I can find the saw. :)
tommykjensen
Gallery: 6 photos
Joined Mar 2004
May 28, 2006 06:30 |  #14
What kind of cheap lights can be used for this?
beckybun
Joined Sep 2004
May 28, 2006 06:31 |  #15
Hmmm...very interesting set up w/ very interesting results...
http://www.beckybun.co​m (external link)
Canon 30D, 10D
Canon G6
Canon 70-200 4.0L
Canon 100 2.8 Macro
Canon 50 1.8 Mk I
Canon 20-35 3.5-4.5
Canon 420EX
UW Alumni
17,662 views & 0 likes for this thread, 13 members have posted to it.
660 guests, 122 members online
