Thread started 17 Sep 2014 (Wednesday) 15:14
Recommended light meters - easy to use and accurate?
southwestform
Joined Sep 2014
Sep 17, 2014 15:14 |  #1
I want to get a good light meter that is very easy to use and accurate for both indoor lighting photos, and outdoor ones to be used with a 5DM3. Can anyone please recommend some models that are both accurate and easy to work with?
Thanks in advance.
marybuck
Joined Sep 2014
Sep 17, 2014 15:20 |  #2
I love my Sekonic L-358. There are lots of YouTube videos on how to use it and the manual is pretty easy to follow. Its around $300. They have a newer model but it is more expensive.
Mary Buck
Photography Instructor Studio 2.8 (external link)
Portrait Photographer (external link)
southwestform
Joined Sep 2014
Sep 17, 2014 15:28 |  #3
Any real advantage to the newer model?
Thank you.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 17, 2014 15:33 |  #4
I concur with L358 suggsstion. I dont see much advantage to the new model, but I haven't really explored it thst closely.
yendikeno
Gallery: 24 photos
Sep 17, 2014 23:19 as a reply to  @ gonzogolf's post |  #5
Another vote for the 358 - love mine, especially when using fill flash.
_____________
Regards,
AZFred
southwestform
Joined Sep 2014
Sep 17, 2014 23:25 |  #6
That model is no longer available at BH. Are either of these the updated versions?
http://www.bhphotovide​o.com …8_Flash_Master_​Meter.html (external link)
Thanks.
SkipD
Joined Dec 2002
Sep 18, 2014 05:15 |  #7
southwestform wrote in post #17162315 (external link)
Thanks.
The L-478D is the closest replacement for the L-358 which does not have a radio module in it for PocketWizard remote triggers.
The L-478DR has a radio module in it. This module is totally useless if you don't use PocketWizard remote triggers.
A number of folks don't care for the touch-screen interface that the L-478D family uses. My first step if I needed to replace my L-358 would be to look for a new (but old stock) unit and then I'd look for a good used L-358.
Skip Douglas
Oldschool1948
Joined May 2012
Sep 18, 2014 05:46 |  #8
marybuck wrote in post #17161514 (external link)
+1. You should be able to find a good used one for around $200-225
5DIII Gripped
AD360 | Canon 600EX-RT (x2) | 580EXII | L358
70-200 f4L IS | 24-70 f2.8L II | 50 f1.8 mk I | Tamron 150-600 G2
Canon Pro-10 Printer | Adobe LR6 | OnOne Raw
Wilt
Sep 18, 2014 09:24 |  #9
Oldschool1948 wrote in post #17162638 (external link)
The used market is an excellent alternative...
  • the Minolta brand meters are very reliable and accurate meters that had the #1 position in the market back in the 1990s and into early 2000's when Minolta withdrew from the meter market, and then the camera division was sold to Sony, as the corporation had financial difficulties.
  • Gossen is a highly respected name from over 50 years ago, and set the standard for meter sensitivity back then with their Lunasix.
Sekonic advanced into prominent #2 while Minolta was #1, then moved into the #1 position in the recent decade. Kenko purchased the rights to the Minolta designs and offer the two most recent models of Minoltas under the Kenko brand name now.
Wilt
Sep 18, 2014 09:33 |  #10
If you are going to spring $220 for a light meter, this is a SUPER buy...the top of the Sekonic line
http://www.apug.org/fo​rums/viewpost.php?p=16​92294 (external link)
The discontinuance of the L358 makes buying them pricey! It could be 'more meter than you need' with its sophistication, but it does everything the L358 does -- and much more.
southwestform
Joined Sep 2014
Sep 18, 2014 14:27 |  #11
I'm a bit unclear as to why I might want the ability to use PocketWizard remote triggers.
I'm planning to get a CamRanger http://www.bhphotovide​o.com …ireless_dslr_co​ntrol.html (external link) to remotely control the camera. Is this the same thing that the PocketWizard Remote Triggers does?
Thanks for all the help!
gonzogolf
Gallery: 561 photos
Sep 18, 2014 16:00 |  #12
southwestform wrote in post #17163572 (external link)
If you had the pocket wizard triggers, you could fire the flashes from the meter rather than using the trigger on the camera, whle metering. The meter module does nothing to the camera.
SkipD
Joined Dec 2002
Sep 18, 2014 16:14 |  #13
PocketWizard remotes are generally used to fire flash units via a radio frequency (RF) signal. The PocketWizard products are primarily used by professional photographers who need them a lot as they are very expensive. I've also heard that the production at PocketWizard is declining, apparently because there is now a lot of less expensive competition.
To answer what I put in bold text above: You don't need the PocketWizard transmitter in a light meter. As described in a post above, there are other ways to trigger your flash unit(s) when measuring light from them.
Skip Douglas
Submariner
Joined May 2012
Sep 18, 2014 19:42 |  #14
Sekonic Flashmate L-308S Digital Light/Flash Meter
About $100 to $120 see http://m.sekonic.com …xposuremeters/l​-308s.aspx (external link)
Works fine.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
K ­ Soze
Gallery: 89 photos
Joined Dec 2011
Sep 18, 2014 20:04 |  #15
I also use a L 308s for my film cameras. Works well and I do not need any other features.
I try to make art by pushing buttons
3,583 views & 0 likes for this thread, 14 members have posted to it.
559 guests, 142 members online
