Thread started 17 Sep 2014 (Wednesday) 16:43
7Dii "Noise" - Imaging Resource raw files
Leigh
Joined Apr 2003
Sep 17, 2014 16:43 |  #1
I downloaded the "House" image CR2 files from 100 to 12,800 ISO; & checked them in 3 raw Converters; Photoshop CS-6/ACR, Photo Ninja, & DPP-3.14.15.
All 3 programs had all/any NR, & Sharpening "shut off".
With ACR, there was a "fair" amount of noise at 1600, & at 3200 it was in the "barely acceptable" range. while I didn't expect results equal to my 6D, though the noise was manageable, I was somewhat disappointed.
In DPP-3, however, there was a "night & day" difference, with much cleaner results, to the degree that ISO 3200 files looked nearly as clean as 800 ISO files in ACR?
I'm not sure what's making the difference, but the files in ACR opened with some "strong" black clipping that needed correcting; whereas in DPP-3 there was no apparent clipping.
Going by the DPP results, it appears that the 7Dii can do quite well at ISO 3200!
I wondered what results others are finding?
Leigh
Palladium
Sep 17, 2014 16:46 |  #2
IMO - you'll get a better idea about the images once the RAW converters are updated with the New Camera profiles. Until then - why bother
gremlin75
Sep 17, 2014 22:13 |  #3
Palladium wrote in post #17161717 (external link)
^This.
Why play with raw files before the camera's profile is in the raw converter??
davidfarina
Gallery: 43 photos
Joined May 2013
Sep 18, 2014 08:04 |  #4
Since he wanted to look at the amount of noise, and had NR and sharpening set to off, why should the camera profile be useful then?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
Leigh
Joined Apr 2003
Sep 18, 2014 08:45 |  #5
Significantly improved "High" ISO noise performance over my 7D's is my primary consideration for upgrading.
There's no reason why a basic evaluation of noise performance shouldn't be performed using the "Standard" profile/s.
In this case, the ISO 3200 shot, in DPP-3 was quite promising-----. I would think, if anything, the actual 7Dii profile may improve it further-----Certainly not make it worse.
Leigh
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 18, 2014 10:37 |  #6
davidfarina wrote in post #17162815 (external link)
Because raw formats change, there have been probably 3-4 different raw formats from Canon alone in the past several years. The 3rd party tools need their developers to reverse engineer the raw data and make changes to their versions of raw converter routines. Canon does this automatically with DPP updates.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 18, 2014 10:45 |  #7
Leigh wrote in post #17161711 (external link)
Leigh
Here is a direct out of DPP from raw JPG at 3200 on a 7D in low light. How does the noise characteristics with what you did compare to this?
http://teamspeed.smugm​ug.com …869097&k=Lj3kXf​7&lb=1&s=O (external link)
Here is 6400
http://teamspeed.smugm​ug.com …869085&k=2tMbDG​P&lb=1&s=O (external link)
To show copy variation, here is another 6400 untouched once out of DPP, but from a different body.
http://teamspeed.smugm​ug.com …343338&k=vThWND​V&lb=1&s=O (external link)
Leigh
Joined Apr 2003
Sep 18, 2014 11:20 |  #8
TeamSpeed wrote in post #17163119 (external link)
The only way to acquire valid noise comparisons between two different camera bodies would be to shoot the exact same scene, with the exact same settings.
The difference is not what either body can do with "bright", evenly lit scenes; but what it can do with "dimly" lit scenes with "harsh" shadows.
Leigh
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 18, 2014 11:37 |  #9
Leigh wrote in post #17163188 (external link)
Leigh
I know that intimately, that is why I supplied VERY low light samples (f2.8, ISO 3200, 1/80th). I assume the samples you pulled for the 7D2 wasn't in low light then. One can compare the noise characteristics between 2 different scenes however, just not the quantity of noise.
travisvwright
Gallery: 21 photos
Joined Feb 2013
Sep 18, 2014 11:43 |  #10
Leigh wrote in post #17162875 (external link)
Leigh
In most cases until the raw converters are updated they are just displaying the embedded jpg.
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
woos
Sep 18, 2014 12:02 |  #11
gremlin75 wrote in post #17162243 (external link)
^This.
If you are using raw therapee you can pick an appropriate profile. :) It will look pretty close to correct--we'll have to see how diff the color filters are vs the 70d and such.
amanathia.zenfolio.com
Shane ­ W
Sep 18, 2014 18:12 |  #12
It surely must be a terrible product then. ...Based on an image review of a camera that is not available yet, nor conversion profiles. And the moon is made of cheese.
Shane W
70D | Sig 10-20 | EF-S 15-85 | EF 70-200 2.8L | Sig 150-500 | Viv 28 2.5 | Sig 30 | Tak 50 1.4 [COLOR=blue]| EF 100 2.8 Macro | 1.4x TC | Nodal Ninja 3 | Tripods | Some Flashes | My flickr  (external link)
stsva
Gallery: 45 photos
Sep 18, 2014 19:14 |  #13
Probably user error, but I couldn't find the "house" image in the 7DII Imaging Resource samples available as of 8:00 p.m. EDT September 18, and DPP 3.14.15 wouldn't open the .CR2 file I downloaded from their standard test image samples. Any thoughts on what I'm missing here?
EDIT: A little Google helped me find DPP 4, which apparently is needed to open 7DII RAW files. I haven't been able to download it; as best I can tell, it's only available from non-US Canon sites and is tied to specific camera models, requiring a serial number from one of those models to download. Unfortunately for me, the 7D I have is not one of those types.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 18, 2014 20:04 |  #14
Use any serial number you find in google images of a 5D3....
For example: http://www.fredmiranda​.com/forum/ufiles/15/9​17015.jpg (external link)
stsva
Gallery: 45 photos
Sep 19, 2014 05:07 |  #15
TeamSpeed wrote in post #17164189 (external link)
Excellent - thanks! :)
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
31,970 views & 0 likes for this thread, 28 members have posted to it.
1457 guests, 129 members online
