Thread started 17 Sep 2014 (Wednesday) 17:32
Collapsible background advice?
southwestform
Joined Sep 2014
Sep 17, 2014 17:32 |  #1
I'm looking for some collapsible backgrounds to use for small item shoots as well as portraits. Besides the obvious difference of collapsible background sizes and colors, I am noticing a wide range of prices for the different backgrounds that comes in different shapes. Are there quality differences with the materials? Is there any particular type I should be looking for? What sizes would you recommend I consider? I would like the backgrounds to be held by either someone else or maybe I can use a C-stand to hold them up.
http://www.bhphotovide​o.com …nds/ci/23697/N/​3974794941 (external link)
Any advice will be much appreciated.
windpig
Chopped liver
Sep 17, 2014 21:17 |  #2
I have this
http://www.bhphotovide​o.com …psible_2_in_1_M​uslin.html (external link)
Expensive, but worth the money. It is very near wrinkle free. The is not a grey one that I've found that comes close to being as wrinkle free. You can get shades of grey with the white by varying your subject to background distance when shooting with flash or continuous lights.
Go ahead, spin the wheel.
lauderdalems
Sep 17, 2014 21:55 |  #3
I just starting using the two items below for shooting head shots - no problems with setups in different buildings...
http://www.bhphotovide​o.com …_574K_X_Drop_Ki​t_5_x.html (external link)
http://www.bhphotovide​o.com …_620k_x_drop_ki​t_5_x.html (external link)
http://gamedayphotos.u​wa.edu/ (external link)
sdipirro
Sep 18, 2014 13:33 |  #4
There's definitely a quality difference with these. I bought some cheap ones initially and the material was so thin that when placed in front of a window, light was streaming through it. I like the Lastolite and Denny collapsibles, but they can be pricey. So I just have a few that work well for portraits. I can often just lean them up against a wall when space is tight. I've found the 6'x7' size to be the most versatile.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
southwestform
Joined Sep 2014
Sep 18, 2014 14:22 |  #5
What about collapsible blue/green screen backgrounds? Anything to look for with these? Are some of the green/blue colors more accurate than others? Any brand or specific model advice?
Thanks everyone!
nycameraman
Joined Jun 2014
Sep 18, 2014 19:46 as a reply to  @ southwestform's post |  #6
I have used Westcott and Lastolite chroma green versions with no issue color-wise.
I guess eventually all collapsible type frames tend to loose shape at the corners.
When that happens, you will get mild wrinkles.
flowrider
Gallery: 127 photos
Sep 21, 2014 16:06 |  #7
Hmmm I'm really liking the X-Drop that lauderalems posted.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
tmalone893
Gallery: 54 photos
Sep 21, 2014 18:56 |  #8
I have the x drop. Very quick to setup and take down.
MaxPreps Profile (external link)
https://www.instagram.​com/theronmalone/ (external link)
lauderdalems
Sep 23, 2014 08:16 |  #9
Nothing fancy - just something simple for head shots
IMAGE: http://joechance.com/temp/setup2.jpg
nycameraman
Joined Jun 2014
Sep 23, 2014 09:25 as a reply to  @ lauderdalems's post |  #10
Regarding Westcott X-Drop, just for information, the back leg extends pretty far out.
2,166 views & 0 likes for this thread, 7 members have posted to it.
561 guests, 142 members online
