Thread started 17 Sep 2014 (Wednesday) 21:06
Manfrotto Magic Arm or Kupo Max Arm or ?
picworx
Joined Jun 2005
Sep 17, 2014 21:06 |  #1
I need to get one of these units for remote camera work at weddings, the prices are spread apart but I prefer to buy the better unit.
http://www.bhphotovide​o.com …43_143_Magic_Ar​m_Kit.html (external link)
http://www.bhphotovide​o.com …upo_KG100211_Ma​x_Arm.html (external link)
Cheers.
The Print is What Really Matters
seres
Joined Apr 2013
Sep 17, 2014 21:24 |  #2
I prefer the variable tension Magic arm, such as the Manfrotto 244N (external link). I can’t tell if the Kupo is variable tension, or simply loose/tight like the Manfrotto 143N.
—Eric
picworx
Joined Jun 2005
Sep 18, 2014 08:47 |  #3
seres wrote in post #17162160 (external link)
Not sure what the difference is between the 2 actually one has a round knob the other a lever?
Echo63
Sep 18, 2014 10:15 |  #4
picworx wrote in post #17162878 (external link)
The variable friction arm allows you to tighten the arms slowly, as you wind the knob, you get more and more drag, until it locks up.
The magic arm with the lever is loose, until the arm is swung round and it locks, its a bit of a pain to use as its very floppy, you really need three hands to work one
(if you have a choice, get the variable friction one)
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
picworx
Joined Jun 2005
Sep 18, 2014 14:43 as a reply to  @ Echo63's post |  #5
Ok I understand now, thx the last question is to get the bracket that is shown or buy the unit with the quick release adapter plate? as shown as I use these plates on my manfrotto tripods.
http://www.bhphotovide​o.com …iable_Friction_​Magic.html (external link)
or is this bracket the preferred choice for securing a remote camera above a wedding couple?
The other issue is whether this arm will support a 5DMKIII with grip?
Echo63
Sep 19, 2014 23:28 |  #6
picworx wrote in post #17163591 (external link)
I have the bracket (not QR) on my magic arm - the QR will be easier to use, but you lose the ability to easily take the bracket off and attach a superclamp, or umbrella swivel or studio flash.
And they should hold a 5d ok
I have used mine with a 1d and 70-200, or 1d/16-35/flash
I use two when rigging to cars though (with suction caps, and lots of safety lines)
You will get a little movement in the camera though, if you need it rock solid, you need to triangulate the mounting (build a tripod out of magic arms)
SYS
Gallery: 602 photos
Joined Jul 2004
Sep 20, 2014 12:51 |  #7
I'd stay away from the Magic Arm that comes with QR which is permanently built into the arm, i.e., there's no way to take the QR off. When I was making the same decision some years ago, that's how it was unless they changed it recently. What I decided to do was to get all the components separately: 1) Magic Arm, 2) Bracket, and 3) QR. With the Magic Arm and the Bracket, you have the choice to employ QR or not.
-Goethe
windpig
Chopped liver
Sep 20, 2014 22:01 |  #8
SYS wrote in post #17167312 (external link)
Ya, I found this out the hard way.
Go ahead, spin the wheel.
2,763 views & 0 likes for this thread, 5 members have posted to it.
1510 guests, 132 members online
