Thread started 18 Sep 2014 (Thursday) 01:17
Strobes with different power settings
shankarj79
Joined Nov 2011
Sep 18, 2014 01:17 |  #1
I am using Elinchrom FX 400 Ri kit , when I am using different powers i.e, in one strobe I set to 2.0 (lowest power) and another set to 4.0. Now the problem is, the strobe with lowest power fires first and after a small interval of time, the second strobe fires :-(. Help me out with if there's any settings has to be changed?
Thanks in advance
Shankar J
Cheers
Shankar J
Canon 60D, Canon 100 f2.8L IS USM, Sigma 10-20mm f4.5-5.6, Yonguo triggers + Nissin Di866 MII + YN 560 II flashes.
https://www.flickr.com​/photos/shankar_j_phot​ography/ (external link)
simonbarker
Sep 18, 2014 09:20 |  #2
They should be firing together and the head with a higher power setting taking longer to cycle than the other head.
It sounds like the pre-flash setting isn't correct, I don't know if this applies to the FX400 but you can refer to the documentation of a D-lite head here http://elinchrom.com …/120313_D-LiteRX-2-4s.pdf (external link)
Refer to pages 11 - 12 and that'll hopefully fix it for you.
nathancarter
Gallery: 32 photos
Sep 18, 2014 11:18 |  #3
What are you using to trigger them? Skyport? Skyport Eco? Optical slave trigger?
Does it happen if they're both at the same power setting? Try swapping the power settings, change one from 2.0 to 4.0 and the other from 4.0 down to 2.0.
Guru_rb
Gallery: 30 photos
Joined Jul 2013
Sep 18, 2014 11:47 |  #4
shankarj79 wrote in post #17162425 (external link)
Thanks in advance
Shankar J
Nice to see another Bangalorean here :-). I use Master RX (600Ws) and FRX200 kits and I have not observed this issue with either of the sets when fired at different power settings.
www.drisha.in (external link)
http://www.facebook.co​m/drishaphoto (external link)
Submariner
Joined May 2012
Sep 18, 2014 19:14 |  #5
Thanks in advance
Shankar J
Dont know your strobes, as I use Bowens.
One mine there is a setting, that allows one to miss a user definable number of preflashes.
You might be able to achieve that result but I doubt it as the optical cell on the second strobe should pick up the first flashes flash and fire the second. As the flash duration is so quick ( in my case either 1/1100 sec or 1/2200 sec ) its really one flash. You definitely cant see the difference.
Sounds like the optical slave on the second is faulty. Thats assuming you left enough time for them to cycle up to full power before going for the real flash.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
windpig
Chopped liver
Sep 18, 2014 21:47 |  #6
I've got a variety of Elinchrom lights. I would also suggest setting the late firing unit into optical trigger mode and see what happens.
Go ahead, spin the wheel.
1,384 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is ShelbyJefferson
662 guests, 121 members online
