Thread started 18 Sep 2014 (Thursday) 06:43
ND filters
jonneymendoza
Sep 18, 2014 06:43 |  #1
Hi all i am looking for a decent ND filter kit for 72. 77 and possibly 82mm lenses i own.
I have heard about the LEE filter systems that seem to be similar to a cokin system and was wondering if i should invest in one of these instead of buying an individual ND filter for different lens threads?
i am looking for 2-4 and possibly an 8 stopper ND filter.
My budget is around 250.
Kind regards
Canon 5dmkIII | Canon 85L 1.2 | Sigma 35mm ART 1.4|Canon 16-35mm L 2.8 |Canon 24-70mm L f2.8 | Canon 70-200mm F2.8L MK2 | Canon 430EX MK2 Flickr (external link)
Canon ­ Bob
Sep 18, 2014 07:13 |  #2
Whilst the Lee system is excellent quality and very adaptable as changes in your lens line-up occur, you'll struggle to get everything on your list for £250.
You'll be typically paying £100 each for the 6 stop and 10 stop and only marginally less for the 2-4 stop filters.
Add in a holder......£50 and adapter rings for you lenses @ £20 each (£35 if you add a wide angle) and you can see where the budget is lacking.
I'd still advise you to go for Lee system but build it up as and when funds permit.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
pulsar123
Gallery: 82 photos
Sep 18, 2014 08:18 |  #3
If you don't need graduated filters, I'd say screw-in filters is a better option - more compact, cheaper, more choices (different brands). Buy filters for the largest lens you have, and then a set of step-down rings - they take little space and are cheap.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 18, 2014 08:56 |  #4
As mentioned above if you don't need graduated filters go with good screw in glass filters. Gowith the largest size and use step rings. Be aware that step rings can cause vignetting on ultrawide lenses.
jonneymendoza
Sep 18, 2014 09:53 |  #5
Thanks. Which company should i look out for Screw glass filters?
gonzogolf
Gallery: 561 photos
Sep 18, 2014 10:35 |  #6
B+w, hoya pro are good. Haida makes a reasonably priced 9 stop filter also look at marumi. It really depends on how much you want to invest and how much effect you want.
pdrober2
Joined Nov 2010
Sep 18, 2014 12:56 |  #7
B+W NDs are great. Buy the 82mm size and then get the 72 and 77mm step up rings for $2 on ebay.
Lee system is baller, but the setup and the filters get expensive quickly. It is amazingly flexible and high quality, but you gotta pay for it!
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
rgs
Gallery: 176 photos
Sep 18, 2014 21:15 |  #8
Agree on screw-ins in your largest diameter and step rings for smaller lenses. It's the cheapest, lightest, and easiest way to go.
Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
The Singular Image (external link)Richard Smith Photography (external link)
Richard Smith Real Estate Photography (external link)500PX (external link)
Fine Art America (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Sep 18, 2014 22:06 |  #9
jonneymendoza wrote in post #17162697 (external link)
Kind regards
Heya,
$250 for quality filters will get you.... 1 or 2 filters. I would suggest you get the biggest filter you can, and use step up rings to use it on any of your lenses. No need to get a filter per lens.
You're going to be hard pressed to find an 8 stop filter. You will find common stop points at 2 stop, 3 stop, 4 stop, 6 stop and 10 stop. If you think you need an 8 stop, just get a 10 stop. You'll eventually want one anyways if you're playing with that much stopping power. Or, get a 6 stop. I find 2 stops to be not really worth it since a CPL stops 1 stop or so on it's own, and you can often drop ISO to 50 on some most professional cameras, producing a similar effect as using a 2 stop filter. I find having a 3 or 4 stop, and either a 6 or 10 stop is a good start.
Really depends on what you are trying to do. I would do a 4 stop and 10 stop personally. Less stacking to get more stopping power. If you get lighter stopping power, you may end up stacking them depending on what you're trying to achieve, and things can get difficult or poor the more you stack (not so much the case with quality filters, but reflections, ghosting, aberrations, etc, can become issues in bright light).
You could use screw-on circular filters, Hoya, Marumi, Haida, B+W all make great filters. If you go the square route, Lee, Haida, and HiTech make some great stuff at reasonable prices. But square filters need holder systems, and this overall gets more expensive very quickly.
It really comes down to what you're wanting to achieve with ND filters.
Very best,
jonneymendoza
Sep 19, 2014 06:46 |  #10
rgs wrote in post #17164304 (external link)
Thank. i will go with this solution :)
mine1
Joined Jun 2012
Sep 19, 2014 09:30 |  #11
If you want to save a little cash you could try Haida filters, they seem to have less colorcast then the bigger names. Might want to check them out, I love mine, but have nothing to compare it to
http://www.flickr.com/​photos/81190407@N08/ (external link)
Canon 60d.Canon 18-135, 55-250 II, and 10-18 stm. and Benro C-1681t Travel Angel, with Sirui K20x head.
jonneymendoza
Sep 23, 2014 09:12 |  #12
mine1 wrote in post #17165134 (external link)
yea i got a 10 stop haia filter and a hoya 4 stop one along with all the step down adapters. job done!
mine1
Joined Jun 2012
Sep 23, 2014 19:17 |  #13
I have that 10 stop and love it
jonneymendoza
Sep 25, 2014 07:42 |  #14
Yea its brilliant!
3,434 views & 0 likes for this thread, 8 members have posted to it and it is followed by 2 members.
ND filters
1461 guests, 136 members online
