Thread started 19 Sep 2014 (Friday) 18:29
New 27" Monitor
El ­ Pedro
Joined Sep 2012
Sep 19, 2014 18:29 |  #1
I'm sure there are a million monitor threads here so sorry for starting another.
I have a mid 2010 27" iMac that I use for work and I need to add a second screen due to some new systems.
I also do about 50% of my editing on this computer the other half I do on my current model macbook pro 15".
I may as well get something that will be great for photo editing that I can have permanently set up as a dual monitor system with the ability to plug my laptop in when needed.
Let me know what I should get and why. Happy to spend up to $1000, more if needed.
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Sep 20, 2014 01:42 |  #2
I would go with one of these
http://www8.hp.com …t-detail.html?oid=579196​0 (external link)
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
Ursyn
Gallery: 63 photos
Sep 21, 2014 04:53 |  #3
I would pick something from EIZO or NEC. I am afraid that $1000 for mentioned 27" monitors is not enough.
NEC (check Wide Gamut monitors or SpectraView):
http://www.necdisplay.​com/category/desktop-monitors (external link)
EIZO (CG and CX series):
http://www.eizo.com …ucts/coloredge/​index.html (external link)
Adrian | flickr (external link) & Instagram (external link)
Kolor-Pikker
Sep 21, 2014 09:25 |  #4
El Pedro wrote in post #17166064 (external link)
Hello, I'm running the same setup as you, a mid-2010 27" iMac and a second monitor, which is an NEC PA272W, and it works great. I actually lucked out and bought this display for $1000 new during a sale at B&H, it's back up to $1,278 now. There really is no comparison to the image quality between the two, as well as the flexibility and build quality of the NEC, but at the price I guess it's to be expected.
The HP is a bit expensive, and would require a method of outputting 10-bit color from your computer to make the purchase worth it. AFAIK, you need an Nvidia Quadro or ATI Firepro graphics card, as consumer graphics don't have 10-bit output, and they cost a whole lot more even for older models, not that you could put one into an iMac anyway.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Mark0159
Gallery: 45 photos
Joined Mar 2003
Sep 21, 2014 21:32 |  #5
Kolor-Pikker wrote in post #17168662 (external link)
yea your right, that monitor is rather expensive, I would go with this instead. http://www8.hp.com …t-detail.html?oid=536729​7 (external link)
if you have got a NVIDIA card then you should have no issues with a 10bit display.
http://nvidia.custhelp​.com …rt-on-nvidia-geforce-gpus (external link)
Mark
Kolor-Pikker
Sep 22, 2014 05:08 |  #6
Mark0159 wrote in post #17169984 (external link)
From the same link:
"this method is not used for professional applications such as Adobe Premiere Pro and Adobe Photoshop. These programs use OpenGL 10-bit per color buffers which require an NVIDIA Quadro GPU with DisplayPort connector"
DirectX 10-bit is no problem, but OpenGL is, and almost all professional applications where 10-bit would actually matter are OpenGL.
Mark0159
Gallery: 45 photos
Joined Mar 2003
Sep 22, 2014 14:14 |  #7
First off that link was last updated in 2011, gforce cards have come a long way since then.
Any new gforce or AMD card will support 4k. With cheap cards that have 2gb of memory they will have no issues. Since 2011 cards have supported 10bit displays but not with opengl, but since then most cards now come with display port connectors that won't be an issue.
Also nvidia is covering the ass if people have issues.
Mark
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Sep 24, 2014 04:34 |  #8
Mark0159 wrote in post #17171304 (external link)
Currently only the FirePro and Quadro cards do true 10bit output.
And once you start rendering anything to 4K the work load for a graphics card gets harder and harder.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
1,830 views & 0 likes for this thread, 5 members have posted to it.
New 27" Monitor
1037 guests, 107 members online
