Do the math...
What shutter speed do you want to use? The fastest possible might be dictated by the flash you are using. 6D's portable flash x-synch speed is 1/180. If using monolights or portable strobes, it might be as low as 1/125. I don't know about ABs, in particular, but because you want to use a strobe in combination with daylight, you won't have as much flexibility with shutter speeds as you would shooting just by available light where you can use much faster shutter speeds. (Note: High Speed Sync might allow higher shutter speeds with portable flash that can do HSS, but limits flash reach dramatically.)
Now what's the lowest ISO you want to use? 6D is expandable to ISO 50, but do you find the image quality acceptable for your purposes? ISO 100 might be your minimum.
Okay, now what aperture are you trying to use? How about f2.8 to f5.6?
Outdoors in sunlight, the "Sunny 16 Rule" says at ISO 100 you need to use 1/100 and f16. In broad shade or overcast it might be f11 or f8. So you still need to "cut" about one stop for the shutter speed and between two to five stops for the aperture. Up to six stops total, in these examples.
So in this example a 6-stop ND filter should allow for approx. f2.8, ISO 50, 1/100 shutter speed in broad daylight. You may be able to play with the ISO and shutter speeds a bit... I.e. you'll have a range that allows for slightly larger or smaller aperture, and for some variation in light. If you want a larger aperture or a higher ISO, you'll need to use a stronger ND filter.
You can stack ND filters. 1- and 2-stop ND filters are generally used for "fine tuning" really precise settings, where you have a very specific shutter speed, ISO and aperture combo you want to use in particular lighting conditions. Otherwise, if you have some flexibility with shutter speed and ISO, I would think a 6-stop ND or 8-stop ND would be more generally useful, giving you a workable range in broad daylight. But if you are looking for larger aperture or slower shutter speeds, you might need a stronger ND... 10-stop and stronger are available. Or if you want to use a bit smaller aperture and/or faster shutter, a 4-stop ND might be right for your purposes.
So first figure out what exposure settings you want, then work backward to calculate how strong an ND you need to get you in the ballpark. If you can be a little flexible in your settings, you'll actually have a range of settings to work within.
