13 minutes (26x30sec)
Desertraptor Cream of the Crop More info | Sep 22, 2014 08:53 | #1 Peter
Sep 22, 2014 11:32 | #2 WOW Peter you are coming along just marvelous ! Ok i see you have 26x30 secs . Is there a reason your only using 30-secs, is it for trailing purposes ? Only thing i would suggest is try using 1 min exposures and stacking 26x1 . More data = Better pictures !
Sep 22, 2014 16:55 | #3 Yeah still having trouble finding the actual SCP. I'm not drift aligning. But after 2 5min untracked shots I now know which star to align too for better than 30 sec. Peter
Peter -- beautiful!
Sep 25, 2014 20:06 | #5 Thanks Spotz Peter
Sep 25, 2014 21:25 | #6 Nicely done! What was your effective focal length? Sony A9, Pentax K1 MKii, Panasonic G9, Sony 200-600, Samyang 12mm F2 NCS CS, 7Artisans 7.5mm f2.8 fisheye, Panagor 90mm f2.8 Macro (OM), , Sigma APO 2x DG EX TC, Tiffen aXent ND 3.0 (ND1000) filter, Olympus OMD E-M5(drown in the Atlantic), Oly 14-42mm, Oly 12-50mm, ZEQ25gt Mount, plus a few other lenses, extension tubes, and general mish-mash
Sep 25, 2014 21:33 | #7 600mm f7.5 Peter
Sep 25, 2014 22:07 | #8 star alignment adjusts pointing accuracy. Polar alignment is what controls field rotation, if you get trails after a minute it is due to declination not being centered with polaris. A drift align is tough but it will do wonders for exposure times. Many of the higher end mounts, takahashi njp, and astrophysics, have very precise polar scopes which allow you to align polaris to within 2 arc seconds or less. These mounts can easily do 10 minute exposures without autoguiding. With a lower end mount, I am not sure what type of mount you own, Ra only causes problems if the load is improperly balanced or if there is stiction in the drive train. I own a zeq25 which is a low end mount, but it does very well with astrophotography, The polar scope in mine was not perfectly square with the mount and the setting circles did not extend down to my altitude so it took a little bit of tweaking but eventually I was able to get 300 second exposures at 1,600mm F8 with perfectly round stars with no autoguiding. Once you are this polar aligned you can easily autoguide 20 minutes for narrow band. You processing came out very well, nice star color and nebulosity processing. I would love to give this data a go if you shared the .tiff. Clear skies peter. Wes
Sep 25, 2014 22:40 | #9 No Polaris here Wes. Our polar star is not visible to and polar scope that would fit my EQ3 mount. But our star is closer to the CSP than Polaris is to the NCP. Peter
legoman_iac Senior Member 308 posts Likes: 50 Joined Nov 2009 Location: Sydney More info | Sep 28, 2014 16:07 | #10 Hey Desertraptor, 2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
Sep 28, 2014 17:19 | #11 Thanks Daniel Peter
griz11 Senior Member More info | Sep 30, 2014 05:07 | #12 Will a Losmandy or Kenko polar scope fit in your mount. It has marking for northern and southern hemisphere. Extremely accurate as it uses 2 stars and has date markings for precession. BackyardEOS makes drift alignment a little easier. At least you don't have to look through guiding eyepiece for a length of time. I had the same problem with houses and streetlights when I had my gear 15 years ago. You could just barely see polaris at the extreme back of the property and there was a big drainage ditch just beyond that. I could get polaris in scope but not the other star. Ended up selling GEM and going with Celestron Alt-Az on wedge. Big mistake but much easier to align using 2 stars. Been getting some nice shots but I'm worthless on the processing right now. I used to use MaxImDL wish I still had it. Just getting started with Photoshop. Drift align is a pain but the signal you can get once its done is excellent. I put a clamp for a smartphone onto a swivel mount that fits into hot shoe. There is an app called star tracker its free and shows you what is in sky where its pointed. Poor mans goto WO 102GT with Flat6 Losmandy StarLapse Dec Axis Servos and SciTech controller Borg guider scope and Lodestar guider Canon 7D 7DMkII Canon 70-200 f4L USM Canon EF400 f5.6L USM Canon 40mm f2.8 STM Tamron SP 70-300 Di VC Borg guider scope and Lodestar guider www.pbase.com/griz11
Sep 30, 2014 05:38 | #13 Griz. I bit the bullet and purchased a skywatcher polar scope today. It has etched markings for both NCP and SCP and lit as well. Hopefully my sky is not LP enough to swamp the SCP through the scope as I do fear it will be. Find out in a few days I guess. What's $100 here and there Peter
griz11 Senior Member More info | You will have better and longer exposures. The one for my mount is 180 WO 102GT with Flat6 Losmandy StarLapse Dec Axis Servos and SciTech controller Borg guider scope and Lodestar guider Canon 7D 7DMkII Canon 70-200 f4L USM Canon EF400 f5.6L USM Canon 40mm f2.8 STM Tamron SP 70-300 Di VC Borg guider scope and Lodestar guider www.pbase.com/griz11
Oct 01, 2014 16:54 | #15 I'm in Adelaide. 2000km SSW of Ipswich. Peter
| Latest registered member is semonsters 930 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
