Thread started 19 Feb 2006 (Sunday) 18:18
RAW is the best? Are you sure?
FlyingPete
I am immune
Joined Oct 2003
Feb 19, 2006 18:18 |  #1
Well, like most around here I started shooting JPG, then discovered the power and flexibility of RAW shooting and proclaimed my dedication to RAW and cast off the inferior JPG.
Many months later I am no longer as sure.
Sure RAW gives you great flexibility etc etc, but at several costs, many I am not sure I want to pay now. Here are my issues:
- Camera speed, I run a 20D, it is noticeably slower in rapid fire, and I regularly full the buffer when shooting RAW, with JPG – no problem, solution getter a better camera
- Capacity, that is obvious. More frequent downloads of cards is a pain in the field, solution there get bigger cards
- Post processing, this is my real issue, I have recently spent far too much time post processing images, and I am kind of over it
Now yesterday I did a shoot, spend a few more minutes getting my exposures right, and got my white balance set correctly, fortunately the condition had controlled lighting. The result, all my images are just right as JPG, and require no post processing, time saves – heaps.
From now on I am cutting back my RAW shooting in favor of spending a wee bit more time getting things set up right, and leaving RAW for when I require the absolute best quality I can get, or if the conditions are photographically “challenging”
Thoughts, feelings flames? :D
Peter Lowden.
EOS R6 and assorted glass
Hellashot
Joined Sep 2004
Feb 19, 2006 18:41 |  #2
It all depends on what you need. You'll be the best looking images from RAW, but if you don't have the time for it then it's not for you. When people talk about RAW being best - it's for image quality which is what most people are looking for, not what is least overburnening.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
Balliolman
Feb 19, 2006 18:56 |  #3
Now you have tried both formats thoroughly, I suppose, Pete, you are now in the happy position to be able to judge which of them will suit your immediate needs based on experience. It seems to me you have made yourself a more accomplished photographer! :D
Balliolman
Stereoshooter
http://www.flickr.com/​photos/balliolman/ (external link)
Want to know more? Q. & A. with Balliolman: 3D/Stereo Photography https://photography-on-the.net/forum/showthre​ad.php?t=150661
DReb; Canon 50 f1.8; Canon 28-135 IS; Loreo LIAC(T); Flashtrax; Canon 17-40 L; Manfrotto 055 PRO B tripod; Canon 28mm 2.8; Whibal
Need: Primes; Would like: Canon 5D;
FlyingPete
I am immune
Joined Oct 2003
Feb 19, 2006 20:16 as a reply to  @ Balliolman's post |  #4
That is the best compliment I have had all day :D
Peter Lowden.
mbze430
Feb 20, 2006 00:11 |  #5
I have no problem shooting in Raw or JPEG. However knowning when to use RAW and JPEG will save you shots. With RAW, you are able to recapture any blown high lights up to 1.5 stop over exposed(for most Canon CMOS sensors) JPeg... bye-bye.
JPEG is like shooting chromes, small latitude in EV range. Exposure must be tack on.
RAW, is like shooting negative film. must wider latitude, and you can manipulate color rendition in dark room (digital dark room).
For events, I shoot jpeg. I know I don't want to go through 300-900 pix. In door events I will shoot raw, specially if there is mix lighting. Unimportant personal stuff.
For RAWs, important shoots, paid shoots. (I don't do weddings)
Though I shoot most of my personal stuff using film :) chromes and neg.
My Hub to my personal work (external link) (just click on the banners)
FlyingPete
I am immune
Joined Oct 2003
Feb 20, 2006 00:58 as a reply to  @ mbze430's post |  #6
That is an excellent summary, it was an event that has got me thinking about just shooting JPG under some circumstances.
Peter Lowden.
toddb
Joined Jul 2003
Feb 20, 2006 02:03 |  #7
That is a good summary.
I wouldn't hesitate to use jpg for allot of things. I can definatly see that when you are shooting an insane amount of images at a time. I've actually used RAW long enough now though that I find post processing even easier and archiving easier as well (see this post.) I think it's come down to automation though for me. Without that, raw would be too time consuming.
I too am starting to focus allot more on getting the setup right to begin with. I've been lacking in this area because I tend to grab the camera out real quick to get a shot of the kids doing something and don'thave time to think about it.
10D, EF17-40L, EF50F1.4, EF28-135IS, 550EX [AlienBees 2xB800 and 1xB400 with large softbox and reversible umbrella] Sekonic L-358
yb98
Joined Feb 2003
Feb 20, 2006 03:27 as a reply to  @ toddb's post |  #8
Why not shoot RAW+JPEG ?
If you are in a hurry use the jpeg.
If you want extra quality the raw is always there.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
FlyingPete
I am immune
Joined Oct 2003
Feb 20, 2006 03:29 as a reply to  @ yb98's post |  #9
You still get the perfromace disadvantages, plus even heavy space utlisation!
Peter Lowden.
EOSAddict
Book Committee Immortal
Feb 20, 2006 03:44 |  #10
Pete,
I wholeheartedly concur with your sentiment about PP, but suggest that if you foolow your new mantra (above) then you wouldn't have to PP in RAW either. I shoot generally RAW but also use JPG when need arises. I too have an aversion to PP and use RSE for the basics and find it takes no longer than it does with JPG, 10 secs per image unless its a 'poor' starting image!
What am I trying to say? Shoot correctly in-camera and you should not need to PP much and then its a matter of taste whether you use RAW or JPG. I tend to use RAW as I hate the thought of throwing 4 bits away the second the shutter fires ;)
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
yb98
Joined Feb 2003
Feb 20, 2006 03:52 as a reply to  @ FlyingPete's post |  #11
For the space is it really a problem since the price of memory cards and hard drives are not expensive in regard to the price of camera and lenses ?
for performance, that's can be a problem..so just use jpeg when you need performance.
By the way, did you try with different memory cards ? The speed of memory cards are not the same. I have compared a memory card of 1 giga and another one of 128 M and I was suprised to see that formatting the 128 M card takes more time than formating the 1 Giga card...
Best DPP Threads
stevefossimages
Feb 20, 2006 11:56 as a reply to  @ yb98's post |  #12
Shooting raw+jpeg will fill your camera's buffer faster than raw alone, compromising your ability to to capture a fast-moving moment. If that's not an issue for you, then you're good to go shooting raw+jpeg.
Steve Foss
Quantum in me fuit
For weddings, reunions, workshops, Realty and guided wilderness photo excursions: www.stevefossimages.co​m (external link)
toddb
Joined Jul 2003
Feb 20, 2006 12:22 as a reply to  @ yb98's post |  #13
That depends on your model as well. I know the 10D doesn't really benifit from the card speed (except for getting images off the card) but does for the 20D. Wait a minute, am I the only one still with this discontinued camera...doh. Someday...someday.
2,098 views & 0 likes for this thread, 8 members have posted to it.
1718 guests, 103 members online
