Thread started 23 Sep 2014 (Tuesday) 13:15
Lighting large group outside with elderly
sdipirro
Sep 23, 2014 13:15 |  #1
I'd like to solicit opinions here. This is an outdoor shoot of a group of 16-20 people. What I would normally do for a situation like this is have two strobes with 7" reflectors on either side of me and up fairly high to create a broad swath of even lighting across the group while not having to worry much about the wind. However, in this case, the center of the group is a woman turning 80, and she will be surrounded by her husband, siblings, children, and grandchildren. The 80-year-old woman has asked me to use the softest light possible.
So I've been pondering whether to shoot this as planned and spend some time in Photoshop with the touch-ups, or might I save myself some work if I used a couple of large softboxes/octas with diffusers to soften the light? Anyone out there with experience doing this that could shed some light on it? Thanks.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
hawk911
Sep 23, 2014 13:18 |  #2
at a distance to get everyone in frame, fine lines and wrinkles will not be much of an issue.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
The ­ Loft ­ Studios
Sep 23, 2014 16:55 as a reply to  @ hawk911's post |  #3
I assume you'll be shooting them in either shade or sun to their back (or side)….. Either way, use the flash as a filler or fill light (to fill in shadows under eyes and such) so it doesn't matter if you use umbrellas or not (even though that wouldn't hurt) because the two 7" reflectors are still being used as "fill". This technique will allow you to keep the "soft light" required by the client. So just as long as the fill light is meter correctly to match that of the ambient "as a fill light", then you'll be O.K…. but personally, I would get a few helpers and use umbrellas.
MARK
sdipirro
Sep 24, 2014 13:20 |  #4
Well, they picked the time for the shoot (11am), but it'll be mid-November, and the sun shouldn't be overhead. I will try to get them in shade with the sun providing some accent/hair lighting, if possible. I will try to underexpose the ambient slightly, and using two RX600 strobes, that shouldn't be a problem. While they *might* want some larger prints too, the primary interest is for 4x8 Christmas cards. So I have to leave room to crop the image to 4x8, which means worrying about fine details even less...unless they do want some larger prints that I'm obviously hoping they do. It sounds like I probably won't have a huge amount of work in Photoshop, and I probably don't have the option of helpers. Thanks for the suggestions.
1,237 views & 0 likes for this thread, 3 members have posted to it.
1698 guests, 139 members online
