Thread started 19 Feb 2006 (Sunday) 19:32
Multiple Speedlite EX question
subtle_spectre
Feb 19, 2006 19:32 |  #1
Hi. I have another question in my never ending quest to master the Speedlite set up and implementation.
If I set a 550 or 580 as "Master" and a 430 as "slave" and do nothing more, what, if anything, is the resultant flash output or result? Do they both trigger as if individually for the same exposure, or do they work in tandem to properly expose the scene? I ask, as it seems easier in the end to set them up this way and simply dial in some negative fec for the fill flash when doing, say, a portrait, and then not having to mess with the ratios and groups.
Thanks.
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
tim
Light Bringer
Feb 19, 2006 23:15 |  #2
By default I believe they will work in tandem to properly expose the scene. Without ratios you'll get a flat look, the idea of multiple lights is to add depth and shadows. You can only have two groups on the subject, group C is for backlight only.
1,093 views & 0 likes for this thread, 2 members have posted to it.
1190 guests, 122 members online
