Thread started 25 Sep 2014 (Thursday) 11:10
Question about viewing photos on my computer
LesF
Sep 25, 2014 11:10 |  #1
Running Win 7 Pro, SP1.
I have set Irfanview on my computer as the default viewer for JPEG photos. The JPEG's display with an Irfanview icon (in List or Details mode), and open in Irfanview when I double-click the icon.
However, when I connect my Canon SX260 HS to my computer via the USB cable, navigate to the camera folder with my photos, and double-click on a photo, it opens in Windows Photo Viewer (although the icons of the photos in the camera still show as Irfanview icons in when viewed in List or Details mode). Why is this happening, and how can I stop it? It's interesting to note that if I right-click the photo and choose Open from the menu, the photo will open in Irfanview.
gug
Gallery: 28 photos
Joined Oct 2011
Sep 26, 2014 05:10 |  #2
If I understand correctly here, to get the photo to open in the desired program you can right click on the pic, go to properties in the dropdown, and in the popup under the general tab is "Opens program with" and if your program of choice is not available click on "Change" button and select from the generic list in the popup or you can add whatever program there as well and make it your default.
denncald
Sep 26, 2014 09:40 as a reply to  @ gug's post |  #3
Follow these steps to set you default photo viewer;
http://www.ehow.com …ure-viewer-windows-7.html (external link)
Dennis
LesF
Sep 30, 2014 14:59 |  #4
Thanks for the replies.
gug, there is no such option when I choose properties from a photo in my camera.
Dennis, as I said in my original post, Irfanview is already set as my default viewer, and works in all cases EXCEPT with photos in the camera.
gug
Gallery: 28 photos
Joined Oct 2011
Oct 01, 2014 05:09 |  #5
If you want to stick with your program, try inserting the SD Card into a computer slot or get a USB SD Card reader and try that.
LesF
Oct 02, 2014 16:03 as a reply to  @ gug's post |  #6
gug, of course I could do that, but I find it more convenient (and quicker) to connect via USB cable.
I'm not looking for work-arounds for this issue, I'm trying to understand why this is happening, so that I can "fix" it.
gug
Gallery: 28 photos
Joined Oct 2011
Oct 03, 2014 04:54 |  #7
Try this (external link). <<< Hyperlink
denncald
Oct 03, 2014 10:06 as a reply to  @ gug's post |  #8
Did you go through the "Control Panel/Default Programs /Set your default" programs to associate Irfanview with your photos? If so, you should also try the "Associate a file type...with a program" for your Jpeg and Raw files to set Irfanview as the program.
Dennis
LesF
Oct 05, 2014 00:41 as a reply to  @ denncald's post |  #9
gug, thanks for the link. Lots to look for there, and I'm still looking.
denncald, yes, I did associate Irfanview with JPGs via the control panel.
However, I don't want to make Irfanview the default for ALL the programs it can open, because I use other default programs for different types of files, even though it's possible for Irfanview to open them.
2,219 views & 0 likes for this thread, 3 members have posted to it.
1330 guests, 109 members online
