Playing around in DPP 4 with some 5D3 files but when I try to send to Photoshop CS5 it say it cannot open Photoshop. How do I set the correct path in CS5.
RoyC Goldmember 2,088 posts Likes: 21 Joined Aug 2005 Location: N.Devon, UK More info | Sep 25, 2014 14:28 | #1 Playing around in DPP 4 with some 5D3 files but when I try to send to Photoshop CS5 it say it cannot open Photoshop. How do I set the correct path in CS5. TOP BIRD SHOTS
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Sep 26, 2014 03:46 | #2 Try converting the CS files in DPP into something that Photoshop can deal with. I use Tiff personally. Richard
Sep 26, 2014 04:03 | #3 Lowner wrote in post #17178357 Try converting the CS files in DPP into something that Photoshop can deal with. I use Tiff personally. Thanks but I do already convert to Tiff. I have been using the 'transfer to photoshop' for a long time with DPP 3 but photoshop fails to open in DPP 4. After doing more web searches I see that lots of people are having this problem with DPP 4. The only work around for me is to convert and save and then open the file from photoshop - same thing but long winded. TOP BIRD SHOTS
DThompson Goldmember 4,059 posts Likes: 415 Joined Feb 2008 Location: Georgetown, Ky More info | Sep 26, 2014 05:41 | #4 There is probably a registry entry you need to change. Dennis
Sep 26, 2014 07:53 | #5 D Thompson wrote in post #17178426 There is probably a registry entry you need to change. You could well be right Dennis, but it is knowing which one. TOP BIRD SHOTS
DThompson Goldmember 4,059 posts Likes: 415 Joined Feb 2008 Location: Georgetown, Ky More info | Sep 26, 2014 15:19 | #6 Take a look here - http://superuser.com …ont-transfer-to-photoshop Dennis
Sep 27, 2014 12:08 | #7 D Thompson wrote in post #17179301 Take a look here - http://superuser.com …ont-transfer-to-photoshop OK I tried that Dennis but unfortunately it did not work, it still said 'Failed to Start Photoshop' Thanks anyway. TOP BIRD SHOTS
Sep 27, 2014 12:32 | #8 I have now worked out a fix for this - more long winded but only a couple of keystrokes. It is done by using Batch Process (it works with a single image). You have to point to the Photoshop path in the applicable field when you do this for the first time but after you have done this once it retains the info. TOP BIRD SHOTS
tonylong ...winded More info | Sep 27, 2014 14:04 | #9 Just as an afternote, DPP is a free "add-on" to our Canon cameras, so when we see glitches, let them know. It seems like they've been pretty good about keeping things "up-dated", just be patient!!! Tony
Sep 27, 2014 14:20 | #10 tonylong wrote in post #17180624 Just as an afternote, DPP is a free "add-on" to our Canon cameras, so when we see glitches, let them know. It seems like they've been pretty good about keeping things "up-dated", just be patient!!! I am not knocking Canon but just asking if any one has come across this and knew of a solution - I will not bother again if prats like you come up with replies like this TOP BIRD SHOTS
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Sep 27, 2014 15:57 | #11 I think you are being unfair, Roy!
| Latest registered member is Marcsaa 506 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
