FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 26 Sep 2014 (Friday) 11:16
Formatting a memory card
tennfan1125
Sep 26, 2014 11:16 |  #1
So I have a Lexar Professional 800X 16gb card that my camera says need to be formatted. How am I supposed to do this. In camera going through the format process it says, Format Card, ALL data will be lost! but when I hit ok it says, "Cannot Format Change Card".
So what am I to do...?
canon 30d, canon 1d mkIII, 50mm 1.8, 18-55mm, canon 1.4 extender, canon 400mm f2.8 IS, canon 70-200 f2.8 IS II, Canon 16-35mm f2.8,Pocket Wizards,430 ex II, 580 ex II, Canon 430 EX, sigma SA-9, 70-300 5.6, 28-80mm(which I NEVER use)
shocolite
Gallery: 55 photos
Joined Mar 2014
Sep 26, 2014 13:15 |  #2
Have you tried formatting the card on a PC/Mac? Or perhaps the card is locked?
Canon 80D, 700D & G7 X; EF-S 10-18/18-135 STM, EF-S 18-135 IS USM, 50 F1.4, 100 F2.8L Macro, 16-35 F4L, 70-200 F4L IS; 100-400 L II, Speedlite 430EX II
John ­ from ­ PA
Joined May 2003
Sep 26, 2014 14:04 |  #3
shocolite wrote in post #17179072 (external link)
In addition to answering these questions, I see by your profile that you have a 30d and a canon 1d mkIII. Which camera is givng you issues and what type card? As I recall the 1DMKIIIcan use SD or CF but the canon 30D is strictly CF.
Also, what is the PC/MAC operating system you have?
Revised...correction to camera and card compatibility
CanonCameraFan
Joined Sep 2011
Sep 26, 2014 21:46 |  #4
30D uses CF only:
• Compact Flash Type I or II
• Microdrive supported
• FAT 12/16 and FAT 32 support
Interesting issue. SD has a slide switch, but CF does not.
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
WhidbeyHiker
Gallery: 64 photos
Joined Dec 2013
Sep 26, 2014 22:54 |  #5
If you can connect it to a computer I would suggest deleting any partition. Place it in the camera and try allowing the camera to format it.
John ­ from ­ PA
Joined May 2003
Sep 27, 2014 09:07 |  #6
Interesting that the OP also has a current thread in which he feels a Lexar 3.0 card reader is giving him an issue. See https://photography-on-the.net …/showthread.php​?t=1399578.
110yd
Joined Jan 2005
Sep 27, 2014 11:10 |  #7
tennfan1125 wrote in post #17178871 (external link)
The Canon 30D can not format the 16 GB card...The max CF card size for the 30 D is 8 GB.
Regards,
110yd
tennfan1125
Sep 28, 2014 00:37 |  #8
I just dont understand why my camera would say "Cannot Format, Change Card1".
CanonCameraFan
Joined Sep 2011
Sep 28, 2014 21:42 |  #9
It cannot format a 16GB card and knows it, thus it says to change the card. There are many generations of controllers and cards, and is apparently aware of the mismatch as noted in post just previous to your last one.
"So what am I to do...?" - tennfan1125
Buy an 8 GB or 4 GB card and try that in the camera.
Jimil
Joined Sep 2009
Sep 28, 2014 22:19 |  #10
John from PA wrote in post #17179154 (external link)
As I recall the 30D can use SD or CF but the canon 1D MKIII is strictly CF.
FYI, you have this reversed. The 1DMKIII had both SD and CF, while the 30D only has CF.
John ­ from ­ PA
Joined May 2003
Sep 29, 2014 08:43 |  #11
Jimil wrote in post #17183054 (external link)
Good catch and I fixed my original comment.
tennfan1125
Sep 29, 2014 20:56 as a reply to  @ John from PA's post |  #12
Ok, so the 30d cannot format the card... I got that but what about a 1d mark III? Can it not format the card either?
whiteflyer
Gallery: 316 photos
Sep 30, 2014 04:10 |  #13
110yd wrote in post #17180385 (external link)
Regards,
110yd
Sorry but that's incorrect
The 30D removed the 8GB limit of the 20D and can support card up to at least 32GB and I'm 99% sure up to the CF spec's maximum size of 137GB.
John ­ from ­ PA
Joined May 2003
Oct 02, 2014 09:56 |  #14
whiteflyer wrote in post #17185509 (external link)
Is that perhaps just part of the issue; the other being what file system does the 30D support? Even a later camera, the 40D for instance only supports FAT32 which only supports a maximum partition of only 32GB.
Keep in mind as well that the OP has a separate thread elsewhere where he suspects issues with a Lexar USB 3.0 card reader so I can't help but think the two issues aren't related.
whiteflyer
Gallery: 316 photos
Oct 02, 2014 13:41 |  #15
John from PA wrote in post #17189888 (external link)
Would be helpful if the OP could tell us if the reader is failing with all cards or just this same card in particular.
If one card, then sounds like the card maybe at fault and needs replacing.
I must say I have never once had a card not format in camera using a 30D, 50D and 1D mkIV, but I do only use 16GB CF cards and a 32GB SD in the 1D
5,180 views & 0 likes for this thread, 10 members have posted to it.
1699 guests, 140 members online
