47 Tuc
Omega Nebula
IMAGE LINK: https://flic.kr/p/pqJKMD
Desertraptor Cream of the Crop More info | Sep 28, 2014 08:11 | #1 47 Tuc Omega Nebula IMAGE LINK: https://flic.kr/p/pqJKMD Peter
Sep 28, 2014 19:54 | #2 Super capture on those two Peter . Very good detail , pinpoint stars , colors right on . Another name for that M17 is the Swan neb .
Sep 28, 2014 21:35 | #3 Thanks Celestron. Had to crank up the ISO for the nebula. Maybe I'll start doing darks to minimise noise Peter
Sep 28, 2014 21:57 | #4 Desertraptor wrote in post #17182956 Thanks Celestron. Had to crank up the ISO for the nebula. Maybe I'll start doing darks to minimise noise If you haven't been adding darks then you definitely need to start . You should have one dark for every 5 or more shots . And remember the darks from one nights shooting are night good for every time you need a dark . Those darks need to be during the same shooting as the image your adding them to . But yes they definitely will help out on the noise for sure .
Sep 28, 2014 22:08 | #5 In process of building a camera cooler. That will help with ISO noise. Should get temps down to negative numbers. Peter
Sep 29, 2014 08:05 | #6 Desertraptor wrote in post #17183032 In process of building a camera cooler. That will help with ISO noise. Should get temps down to negative numbers. Yes it will help but darks help cover bad pixels that are in each shot . That's those little red & blue specs you see all over an image at times .
Sep 29, 2014 16:45 | #7 I have noticed there are many hot pixels floating around Peter
| Latest registered member is semonsters 930 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
