Thread started 02 Oct 2014 (Thursday) 00:17
lens barrel coatings
bk2life
Gallery: 18 photos
Joined Nov 2010
Oct 02, 2014 00:17 |  #1
Has anyone tried "plasti-dip" for their lenses?
I’ve seen some people paint them different colors, and add the camo wraps to them as well.
In the car industry, plasti-dip gets sprayed on from a can, and is able to be peeled away when you don’t want it.
It’s strong, durable, and i think would work well to change the color of your lens barrels/bodies..?
YouTube has many videos on what and how to plasti-dip.
Any thoughts?
-james
5Diii|7D|Nifty 50|Canon 17-55mm-2.8|Canon 70-200L 2.8 IS ii|2x 600EX-RT|ST-E3-RT|CS6
nellyle
Joined Jan 2012
Oct 02, 2014 00:20 |  #2
Easier to just buy a lens coat. Unless you're going to completely strip down the lens before you do it, it strikes me as a bit risky.
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Oct 02, 2014 00:33 |  #3
Retail cost of lens coat - $80 average.
Painting lens - $20
LOSS of value when painting lens - BIG... depending on lens but take a entry L lens at around 1,000 bucks you could easily lose 300 dollars by doing what you are describing.
The look on other photographers faces when they see your plastidipped lens = priceless.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
ZoneV
Oct 02, 2014 02:17 |  #4
In last years more and more people try to have lenses that look different to other lenses.
To spray a lens you should disassemble it partly, and take into accout that the new color add thickness. This could be very problematic for example for the zoom and focus rings and their near by parts.
Here you find some examples how it could be made with a good looking result:
http://parkinstyle.tis​tory.com/ (external link)
Don´t know how the lens handling feels now and 5 years after heavy use - and how it looks like after that time.
I would not reccomend such an modification.
Talley wrote in post #17189313 (external link)
At least when you coat it by dipping it into the plasti-dip :-)
DIY-Homepage (external link) - Image Gallery (external link) - Gear List
bk2life
Gallery: 18 photos
Joined Nov 2010
Oct 02, 2014 03:07 |  #5
nellyle wrote in post #17189299 (external link)
wouldn’t need to strip it down at all. Few pieces of masking tape.
Painting lens - $20 you could easily lose 300 dollars by doing what you are describing..
you didn’t look at any of the youtube videos, or any other information about it did you? You just described how you felt. Thanks.
ZoneV wrote in post #17189398 (external link)
I wouldn’t, id just mask off the areas. Very simple.
Basically I’ll try this again, plasti-dip is a brand, and it sprays out of an aerosol can. When it dries in a few minutes it is a rubber like material that EASILY PEELS off leaving whatever you sprayed it on perfectly unharmed.
Many people are using this product on various things such as phones, bikes, car wheels, entire cars, and other parts and pieces. When they don’t want it anymore it peels off.
So, if a lens was sprayed with this stuff, you could easily peel it off when done.
-james
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Oct 02, 2014 03:57 |  #6
bk2life wrote in post #17189423 (external link)
Well aware of what it is.....
Please do not try this!!!!!!!!
For the sake of the sun gods and the alignment of the stars, moon and universe you will upset the very existence we live in.
My Gear Archive
bk2life
Gallery: 18 photos
Joined Nov 2010
Oct 02, 2014 05:29 |  #7
Talley wrote in post #17189452 (external link)
Please do not try this!!!!!!!!.
well since you put it that way, i will try it, and ill do it with a big smile knowing you said no..
-james
carpenter
Gallery: 12 photos
Oct 02, 2014 07:26 |  #8
I've plasti-dipped a couple smaller parts on my car. I think it would be fine as long as you were careful not to get any in between the focus and zoom rings and of course you couldn't do any part of a lens that extends out as plasti-dip will be too thick and can't be used on any part that rubs such as behind the AF/IS switch selector. Also not sure that it would work to do under the zoom and focus ring rubber grip as they might not fit back over and I don't think I'd do it over the rubber grips so might be better leaving those black as they are.
If you haven't worked with it yet then practice on some stuff, because you definitely have to learn how to apply so it doesn't build out or get "fuzzy" when you spray it. That said, I wouldn't have the nerve to try it on a good working lens. Might try to find some lens that has little to no value as my test lens.
5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
slathrum
Joined Dec 2012
Oct 02, 2014 08:39 |  #9
I would think where plasti-dip would get a little dicey, is at the lens controls (auto/manual focus etc). I've also found that plasti-dip can be a little tough to clean without damaging it. I have gunmetal plastidip on my jeep wheels, and it's been ok for a few months now. I don't think I would do it on something that is handled frequently though.
Have you thought about vinyl wrap?
pkim1230
Joined Apr 2011
Oct 02, 2014 10:36 |  #10
http://www.youtube.com​/watch?v=ewP2R1zfzvY (external link)
looks like a common canon white lens.
I found a blogger who does this professionally. I don't know if he uses plastidip though.
http://cafe.naver.com/​enjoyreform/13122 (external link)
http://parkinstyle.tis​tory.com/73 (external link)
http://parkinstyle.tis​tory.com/71 (external link)
Pretty crazy. he disassembles it and does it.
Gear | 6D, 550D, 1000D IR Modified, Samyang 24mm f/1.4, Rokinon 14mm f/2.8, Canon 40mm f/2.8, Tamron 70-300mm VC f/4-5.6, iOptron SkyTracker
2,917 views & 0 likes for this thread, 7 members have posted to it.
883 guests, 128 members online
