Thread started 20 Feb 2006 (Monday) 08:42
Canon Speedlight 177A on a 10D?
onedownfiveup
Joined Nov 2005
Feb 20, 2006 08:42 |  #1
I found my parents old Canon SLR accessories such as lenses and their speed flash. The lenses aren't EOS lenses so they aren't going to work, but I want to know if the Speedflash will work. I read some where that if you don't have the right flash for the right camera it can screw up the camera. Before I go trying it out and putting it on the camera I want to knwo for sure if it's ok. haha
Canon 20D | Canon PowerShot A520 | Canon 200EG Deluxe Backpack | 18-55mm Kit Lens | EF 50mm f1.8 | 2 Vivitar 285HV's | 2 Pocket Wizard Plus II | 2 8' Light Stands and Flash Brackets| 2 Impact 32" White with Black Removable Backing Umbrella's
Jon
Joined Jun 2004
Feb 20, 2006 09:14 |  #2
It would only work in manual flash mode. You should measure (between the big bottom contact and the one on the edge of the shoe mount) the trigger voltage. The 10D gets very unhappy (to the tune of frying your shutter over time) if you use flashes with trigger voltage of over 6 V.
Jon
Cocker Spaniels
onedownfiveup
Joined Nov 2005
Feb 20, 2006 09:42 as a reply to  @ Jon's post |  #3
I'm not even going to try and use it then. No need to worry about all that. I'll just go and buy a flash suited better for what I want to do. I just figured since it wasn't being used why not put it to use if it can be put to use.
1,088 views & 0 likes for this thread, 2 members have posted to it.
1217 guests, 122 members online
