Is it possible to feather a beauty dish? I've tried it without a sock, and although there was some feathering, it looked pretty terrible. I tried it with a sock, and I was kind of getting the feathered look, but it wasn't as great.
Oct 05, 2014 15:16 | #1 Is it possible to feather a beauty dish? I've tried it without a sock, and although there was some feathering, it looked pretty terrible. I tried it with a sock, and I was kind of getting the feathered look, but it wasn't as great. Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
Oct 05, 2014 15:36 | #3 whoty wrote in post #17195359 Yes, it's possible. Works best when you use a dish as a dish, really close to the subject. For example, beauty work. I kind of currently use my BD as my catch-all. I really should have bought an octabox instead for my kind of shooting. :S Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
LeftHandedBrisket Combating camera shame since 1977... More info | See my light leaks thread on the first page. Not the same, but a similar problem. Part of my goal was to tame the hot spot on the outside edge. Once you do that I'm guessing that flags and definitely feathering will be much easier. I just haven't gotten that far. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Vitoflo Senior Member 271 posts Likes: 3 Joined Aug 2013 Location: Venice Italy More info | Oct 06, 2014 12:45 | #5 PermanentlyI think this viedo could help (Overhead Beauty Light): https://www.youtube.com/watch?v=kAktsvgtro0
OceanRipple Member 244 posts Joined Jan 2014 Location: UK More info | Oct 06, 2014 13:38 | #6 It's a useful video, but using a sock changes things up immediately - close to a round softbox.
Oct 06, 2014 14:08 | #7 Permanent banYou can also use the circular diffuser that comes with the collapsible 5-in-1 reflectors. Do note that this will change your colour temperature. Note that the penumbra is different and thinner than the one you get with bowl reflectors: 12" reflector: Longhorn reflector: Mind you, you'd need to make similar images with your gear so that you can study their own particular patterns. Knowing where your light boundaries are would definitely help, methinks. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
Oct 06, 2014 19:37 | #8 To clarify: I use a sock, and I honestly prefer to the majority of shoots. Very seldom do I like a pure beauty dish. Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
| Latest registered member is semonsters 1452 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
