Where in/on the Canon 20D do you get the info on how many captures you have taken with your camera?
TIA
Lynn
Feb 20, 2006 10:43 | #1 Where in/on the Canon 20D do you get the info on how many captures you have taken with your camera?
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 20, 2006 10:48 | #2 If you haven't loaded a CF card from another camera in there, and if you never reset the frame counter, and if you aren't concerned about remote captures where the file was written only to the computer, it's a combination of the file and folder numbers. File number for the first 9999 shots, then add 10000 for every hundred starting at folder 200. Jon
Jon wrote: If you haven't loaded a CF card from another camera in there, and if you never reset the frame counter, and if you aren't concerned about remote captures where the file was written only to the computer, it's a combination of the file and folder numbers. File number for the first 9999 shots, then add 10000 for every hundred starting at folder 200. Thank you Jon
hoopmatch.com Hatchling 2 posts Joined Feb 2006 Location: Alma, Michigan More info | I've noticed on my 20D (and also on a Pentax *ist D) that the LCD "picture counter" always under reports the number of pictures I can get on the compact flash card.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 20, 2006 13:48 | #5 The "frames left" is a guesstimate based on your ISO setting and how large a typical photo will be at your current resolution/compression settings. If you take pictures that can be compressed more than "typical", you'll get more than the counter indicates. Jon
Kennymc Goldmember 1,501 posts Joined May 2003 Location: N.E coast of UK More info | Also the complexity of the image will effect the file size... Images with loads of fine details like tree leaves and loads of flowers take up more MB than a shot of a deep blue sky... www.kennymc.com
| Latest registered member is semonsters 1607 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
