Slightly embarrassed to be asking this question, but...
I saw a photographer using a piece of equipment, and I want to buy one. I just don't know its name!
The piece of equipment is a white panel; it appears that has a base section that sits on the ground, you then pull the panel up from the base section; it's probably on a roller inside so you unroll it up to about 6 or seven feet high. Then there is a support that you connect to the base unit and the top of the panel, and it stays vertical (ish).
It's a bit like an exhibition stand, but all white
I would be looking to use this as a kind of baffle for the edges of my HiLIte when taking photos with more than one or two people in them
Can anyone tell me what the name of this kind of thing is, please?
Thank you!
