Thread started 09 Oct 2014 (Thursday) 11:45
Setting up wireless Pro1/10/100 on Verizon FiOS
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Oct 09, 2014 11:45 |  #1
Has anyone successfully set up their Pro1/10/100 printer on their home network with Verizon FiOS WITHOUT using an ethernet cable to connect to the router? I want to take advantage of the wireless feature. I already have the printer set up and it's working while being plugged into the router. I send the print jobs wireless over the network. Just want to get rid of the ethernet cable.
I know that the WPS button isn't activated on the Actiontec router that FiOS uses, so I can't connect using the usual set up instructions. Is there a way to set it up through the router's browser set up?
Thanks.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Oct 09, 2014 20:30 |  #2
Sorry can't help with your actual issue but FYI the Pro 1 does not have Wi-Fi, only the Pro 10 and 100 have Wifi. Friend has the Pro 100 and decided to stick with cables because of the file size when printing from TIFF.
Dan Marchant
biglipps66
Joined Sep 2014
Oct 09, 2014 22:34 |  #3
Could be a number of things ya.
Check printer support for wifi
If it has it make sure wifi turned ON on printer
Make sure its connected to network and has address if so
Make sure software knows to connect to it wirelessly
PM me for more info lol
Nathan
Gallery: 18 photos
Oct 10, 2014 10:05 |  #4
Woops. Didn't know that the Pro1 wasn't wifi enabled.
biglipps... your advice sounds like the stock instructions. My issue is one needing a backdoor solution. I need the printer to communicate with the router wirelessly. Thanks.
Eyeball2
Joined Jun 2014
Oct 10, 2014 10:15 |  #5
Just a quick look here (page 6) seems to indicate that you can use an alternative wifi setup by temporarily using a USB cable. Have you tried that?
http://www.usa.canon.c​om …/PRO-10_Router_change.pdf (external link)
Nathan
Gallery: 18 photos
Oct 10, 2014 10:27 |  #6
I'll give that a try. Thanks.
I think I read previously that the usb port on the FiOS Actiontec routers aren't enabled, either... I'll have to check that.
Eyeball2
Joined Jun 2014
Oct 10, 2014 10:35 |  #7
I'm pretty sure the USB connection is from PC to printer, not to the router.
Also, take a look at this thread. Seems to imply that you should be able to enable wifi on the printer while using your current printer-cabled-to-router setup. Once it's enabled, you should be able to disconnect the ethernet cable.
https://photography-on-the.net …/showthread.php​?t=1364330
1,996 views & 0 likes for this thread, 4 members have posted to it.
1458 guests, 127 members online
