Reservoir Dog wrote in post #17209324
I've tried to find this option too though i don't shoot video, but in case of ... i wanted my video on the SD too with the jpg.
It might be BS what i will say next, but may be we cannot (or Canon does not implant it) due to the hardware limitation on the SD card side (if i recall what i've read somewhere on POTN, it's 20MB max speed, so whatever speed SD card you put in, cannot go faster than 20MB)
Hmmm! has that been stated/documented anywhere by Canon or other test reviewers?
Looks like the only way to implement the CF stills and SD videos is to set the card select to "standard" and manually pick the card depending on the choice needed...............but is there a quick way to select the CF or the SD, one button press or two at the most...............the more I think about this could be a menu option where the card selection choice should have been there pick that says "when switching from still to video do you want the SD card to be chosen" simples eh!
But back to the point is there a rapid way to switch from CF to SD as needed manually?
Edit ~ found this about the cards in the manual page 370:-
If the card’s writing speed is slow, movie shooting may stop
automatically. When the compression method is set to [IPB], use a CF
card with a reading/writing speed of at least 10 MB per sec., and a SD
card with a reading/writing speed of at least 6 MB per sec. When the
compression method is set to [ALL-I (I-only)], use a CF card with a
reading/writing speed of at least 30 MB per sec., and a SD card with a
reading/writing speed of at least 20 MB per sec. To find out the card’s
reading/writing speed, refer to the card manufacturer’s website (p.219).
