Thread started 13 Oct 2014 (Monday) 13:19
Bloated stars issue
Jeff
Oct 13, 2014 13:19 |  #1
Hello Smart People!!!!!
I just got a new scope :) and I'm getting some unexpected results from it. It's a 110mm Orion Eon ED APO f/6. I'm using it with a Canon 70D, a field flattener and the Orion Skyglow Imaging filter. (I get the same results without the filter)
Notice how the redder stars have a little halo/bloat/ring around them? Is that normal from a scope like this? How might I reduce it. I've been shooting at ISO800 for 4 minutes for each image.
I had an 80mm Cestron ED non-APO and I didn't get these little rings.
Attached it a 100% crop of one of the images.
Thoughts?
Jeff
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/10/2/LQ_697314.jpg
Image hosted by forum (697314) © Jeff [SHARE LINK]
Jeff
70D | Tokina 12-24 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: QHY268m, Astronomik Deepsky LRGBHaO3S2 filters, Meade 10" SCT, Astrotect 130EDT APO (.8x), iOptron CEM60 to keep it all off the ground.
MY AIRPLANE PICS (external link) | MY ASTRO PICS (external link)
legoman_iac
Dec 27, 2014 04:49 |  #2
Hi Jeff,
I gets bloated stars when using my 30mm f1.4 lens ... Have assumed it was either: focus issue, thin clouds or sometimes from shooting inside looking through glass doors.
Any of these sound like possible?
- Daniel
2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
mainbyte
Joined Mar 2011
Dec 27, 2014 10:47 |  #3
It looks like longitudinal chromatic aberration to me.
Ron
Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
calypsob
Joined Jan 2012
Jan 08, 2015 23:20 |  #4
That is perfectly normal, it is star color in the stars. Understand that the 110mm eon is actually a doublet and could indeed yield chromatic aberration however this image simply demonstrates stars which are not correctly white balanced and they are surrounded by their actual color. If you align the rgb channels in camera raw before opening the image you will have a more accurate representation of the colors. Also if you select the back ground with the magic wand, invert selection expand 3 pixels, saturate to 50% and then Gaussian blur the selection the entire star will become colored.
Wes
Gear: Many gears Yes.
AbPho
Jan 10, 2015 10:57 as a reply to  @ calypsob's post |  #5
I tried your suggestion Calypsob but it only emphasized the halos. Do you mind clarifying the process and maybe posting some sample pictures? Thanks.
I'm in Canada. Isn't that weird!
Jeff
Jan 11, 2015 13:52 |  #6
Thanks for the info guys, I'll give the suggestion a try and see what I can come up with.
Jeff
calypsob
Joined Jan 2012
Jan 24, 2015 04:23 as a reply to  @ AbPho's post |  #7
yes, here is a tutorial which spells it out better http://www.astropix.co​m/HTML/J_DIGIT/STARCOL​R.HTM (external link)
Wes
AbPho
Post edited over 8 years ago by AbPho.
Jan 24, 2015 08:48 |  #8
Thanks Calypsod.
3,031 views & 0 likes for this thread, 5 members have posted to it.
Bloated stars issue
1588 guests, 137 members online
