lapino wrote in post #17211605
I'm currently very much in doubt which camera I should get (a 7DII or Nikon D750). APS-C vs FF. I have shot with both systems for a couple years but never side by side. I'm looking for good lowlight performance and fast AF in all situations.
Both cameras I can afford with some nice primes, but when it comes to zooms, I could buy the 7D2 with the 17-55/F2.8 and still spend less then buying a FF with a F4 zoom.
Now I wonder if I would lose IQ when going for APS-C compared to the FF. Anyone can comment on this.
I know DOF will be a tad less on the APS-C but I wonder when you compare F2.8 on APSC to F4 on FF if the difference would be noticeable. I tend to use (need) high ISOs too though, mainly to keep the shutter speed high. When using a F2.8 zoom, I suppose that's easier on APS-C then compared to a FF when using a F4 lens.
Thanks for your input.
IF you frame with both cameras using the FL appropriate for the format to obtain the same AOV, the APS-C (e.g. at 31mm) has MORE DOF than FF (e.g. at 50mm) at the same aperture, not less as you stated!
Because the 14.9 x 22.5mm image of APS-C has to be magnified by 1.6x greater than the 24 x 36mm frame of FF to make the same FINAL PRINT, the lens' OPTICAL RESOLUTION is always taxed to a greater degree by the smaller format.
As someone who shot medium and large format film cameras professionally, putting my 135 format gear to rest only until I wanted something suitably compact and lightweight for vacations, I can say that most of the time I shoot APS-C and rarely ever say "I wish I had my FF camera with me instead!" for personal leisure use. So the quest for 'more IQ' does go overboard for a lot of folks. If you NEVER make a print larger than 13" x 19", you likely will never appreciate any IQ advantage of the larger FF camera, apart from the fact that larger pixels capture more photons and result in lower noise images than APS-C.
