Thread started 14 Oct 2014 (Tuesday) 13:24
Your White Balance Methods Dim-lit HS Football
UTgws
Oct 14, 2014 13:24 |  #1
I am struggling with white balance on these dim lit high school football fields. For Friday night shooting here in North TX I am getting some natural light of warm up action through to the questionable lighting once the sun goes down. Using AWB gives results all over the Kelvin scale and the colors are very inconsistent. I am using Lightroom for PP, and have tried using the eyedropper to sample a "neutral" but not every shot has an appropriate neutral to sample which produces stuff all over the place. I would really like to get to a point where I could batch set the WB but with the quality of light that we have on HS fields I haven't found a way to do this.
I am fighting the use of flash, going to fight that till it whips me into being no other way too. Does anyone have a flow for setting their white balance;
Start out with manually setting it in the camera?
Adjust camera settings as night fall in?
Anyway once in post, to adjust the whole image set?
Gary
Started shooting sports in high school in 1975, after high school, took a 35 year nap from photography and picked it back up in 2012 and getting more serious with the art.
Gear - Some Canon camers and lenses.
clayteague
Joined Sep 2014
Oct 14, 2014 13:53 |  #2
Gary, as you found out. the problem is that at some high school fields (and basketball gyms), the lighting actually changes color temperature very fast.
It doesn't matter if you set a custom white balance or use a gray card. Every photo will have a different color temperature.
There is nothing you can do about it.
The best thing I have found is to apply the AUTO white balance setting in Lightroom to every photo which will get you close and then make adjustments as necessary.
tmalone893
Gallery: 54 photos
Oct 14, 2014 14:47 as a reply to  @ clayteague's post |  #3
1. If you use a white or gray card, make sure your shutter speed is 1/60 or less to avoid the cycle and use that as your white balance point. Fill the frame with the card and set your custom balance. Adjust your setting back to where you had them and get to shooting.
or
2. Give in to the use of flash. Your pictures will get a lot more pop and the colors will look great. Once you learn the K value using the flash at night, it is simply setting it before the action starts and that is one less thing to edit. :D
MaxPreps Profile (external link)
https://www.instagram.​com/theronmalone/ (external link)
DC ­ Fan
Oct 14, 2014 16:50 |  #4
UTgws wrote in post #17212588 (external link)
Since there's no way to stop color balances from changing under the circumstances mentioned, it'll be necessary to keep track of those changes.
A few people use the ExpoDisc (external link) gadget to determine white balance, or a cheap knockoff (external link).
And, color targets (external link) have long been useful, along with grey and white targets (external link).
The least expensive variation may still be a plain piece of white paper.
Unfortunately there's no way to control lighting unless the school or high school federation allows flash, and even flash, if allowed, has a limited practical range.
UTgws
Oct 15, 2014 07:12 |  #5
Well you all are confirming my suspicions, I was sure in hopes of a better solution.
Gary
clayteague
Joined Sep 2014
Oct 16, 2014 14:00 |  #6
Using an Expo Disc or gray card or white paper can not help because the color balance of some stadium lights CHANGES rapidly and will be different from one frame to the next. Also some lighting grids actually flicker as well and will make your exposure jump up and down.
airfrogusmc
Gallery: 179 photos
Oct 16, 2014 14:16 |  #7
tmalone893 wrote in post #17212750 (external link)
Actually if it is fluorescent you can shoot up to 1/125 but you have to use even shutter speeds. 1/125, 1/60/, 1/30, 1/8, 1/4 etc...
ChunkyDA
Gallery: 17 photos
Oct 16, 2014 20:33 |  #8
And your meter is reading the most light that will be present since the lights flicker off faster than your meter is seeing. Chances are pretty good that the colors will be poor and the amount of light will be less than your meter is telling you when using a fast shutter speed.
I made an animated gif to illustrate, referees walking in top of frame illustrates the sequence. Each 1 of 4 shots is 1/1000 sec to stop the action and you can see the light on this field just plain sucks. 5D3 at 5ish frames per second.
You can not take a single shot on a grey card and set WB on this field, you will be wrong most of the time due to the flicker.
Dave
Support Search and Rescue, Get Lost (external link)
Gear list and some feedback
UTgws
Oct 16, 2014 20:51 |  #9
Yup, that is exactly what I am talking about Chunky.
Gary
airfrogusmc
Gallery: 179 photos
Oct 16, 2014 20:59 |  #10
Yes if you have to shoot above 1/125 you are not going to get any consistency with color in certain types of lights like fluorescent.
3,461 views & 0 likes for this thread, 6 members have posted to it.
1044 guests, 104 members online
