outmywindow Senior Member 672 posts Likes: 3 Joined Jan 2013 More info | Oct 17, 2014 10:55 | #2
Just a soul with a camera
Oct 17, 2014 11:10 | #3 Permanent banI have a 17-40. It is a bit bigger than the 10-22 I moved up from. Pretty sure it isn't quite 97 inches long, though. I'll get back to you. WARNING: I often dispense advice in fields I know little about!
sirquack Goldmember More info | Oct 17, 2014 12:13 | #4 I just checked my 17-40 and it is just a touch shy of the 97 inches reported above. Something like 90+ inches shy. But who is counting. Name is Ron.
Oct 17, 2014 13:14 | #5 97 inches? Gear: 7D II, 6D | EF-S 17-55 | 35/2, 85/1.8, 35 L,100L,135L, 24-70L II, 24-105L, 70-200 F/4L IS, Sigma 150-600 C | 580 EX II, 270 EX II
Oct 17, 2014 13:18 | #6 Same scale I use when I talk to the ladies! 5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
Oct 17, 2014 13:30 | #7 carpenter wrote in post #17218359 Same scale I use when I talk to the ladies!
Oct 17, 2014 13:35 | #8 Lucky ladies ... Gear: 7D II, 6D | EF-S 17-55 | 35/2, 85/1.8, 35 L,100L,135L, 24-70L II, 24-105L, 70-200 F/4L IS, Sigma 150-600 C | 580 EX II, 270 EX II
timbop Goldmember More info | Oct 17, 2014 19:34 | #10 l89kip wrote in post #17218393 Lucky ladies ... until the rude awakening that it's actually 97 mm Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
AbuMahendra Senior Member 368 posts Likes: 1 Joined Aug 2013 More info | Oct 17, 2014 20:21 | #11 Permanent banAlright, ladies, which one do you prefer?
Oct 17, 2014 20:46 | #12 |
timbop Goldmember More info | Oct 17, 2014 20:47 | #13 davidfarina wrote in post #17218929 Big? I find my 16-35 2.8 small and light compared to bricks like the 50L, 24TSEii or 70-300L look at the units of measure on the lenses. hint: it isn't correct Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
I must be stupid or something, but how do you get 3 measurements for something basically cylindrical? Edward Jenner
| Latest registered member is semonsters 1497 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
