Thread started 17 Oct 2014 (Friday) 15:46
35mm f2 IS underexposing?
The ­ Dark ­ Knight
Joined Apr 2012
Oct 17, 2014 15:46 |  #1
This is weird, but my 35 f/2 IS seems to consistently underexpose by about 1/2-1 stop.
I don't think this is a camera body issue, and my other lenses work fine on my 6D. Not a huge problem since I can compensate by overexposing a bit, but has anyone else maybe noticed this about this lens?
windpig
Chopped liver
Oct 17, 2014 16:30 |  #2
Does it do it at all F stops?
What are you using for metering?
Go ahead, spin the wheel.
dadgummit
Oct 17, 2014 18:21 |  #3
I wonder. Can the lens report a faster aperture to the camera than it is actually using? If it is telling the camera it is at f5.6 but the blades are closed enought to be f8 it would do this. Just guessing.
Personally I would go to a local camera shop (Like Sammy's here in socal) and try one of their demo copies.
My Humble Gear List
I shutter to think how many people are underexposed and lacking depth in this field.Rick Steves
artyH
Oct 17, 2014 18:40 |  #4
My Canon 50f1.4 overexposes by 1/3 stop. This can be a problem outside, but hasn't been for low light shooting
My 35F2IS has been right on for both my cameras.
frugivore
Gallery: 11 photos
Oct 17, 2014 18:42 |  #5
Can you post a sample with EXIF intact?
Abu ­ Mahendra
Joined Aug 2013
Oct 17, 2014 20:35 |  #6
The 35IS has significant vignetting. Its actual transmission is not f/2. This why, relative to, say, f/2.8, a shot at f/2 will be underexposed. Ditto for the many other fast lenses.
jrscls
Gallery: 158 photos
Oct 17, 2014 21:09 |  #7
^^ Agree with the vignetting, but according to the link below, the T-stop value is 2 for this lens vs. f2.3 for the old non-IS version. So that wouldn't explain the underexposure.
http://dustinabbott.ne​t …ef-35mm-f2-is-usm-review/ (external link)
Sony A1, 24-70mm f/2.8 GM II, 70-200mm F/2.8 GM OSS II, 200-600mm f/5.6-6.3 G OSS, 35mm f/1.4 GM, Viltrox 16mm f/1.8, 1.4X TC, Flashpoint flashes
The ­ Dark ­ Knight
Joined Apr 2012
Oct 17, 2014 21:27 |  #8
Abu Mahendra wrote in post #17218918 (external link)
Yep, this was it. The vignetting was so heavy I thought the entire picture was underexposed. Whoops. That and poor lighting conditions made it worse. Easy LR fix.
Abu ­ Mahendra
Joined Aug 2013
Oct 17, 2014 21:49 |  #9
jrscls wrote in post #17218957 (external link)
I'd first look to the vignetting map of DXO, SLR Gear, Lenstip, Photozone and DP Review first. They all show the 35IS to have significany vignetting at f/2.
I always dial in +1/3 stop exposure comp (and HTP to take care of any over-exposure at other apertures) so I don't notice it on most shots. Dial in, and forget. I also shoot RAW only, so you can fix, if needed, in DPP.
GeoKras1989
Joined Jun 2014
Oct 18, 2014 04:01 |  #10
My 35 IS doesn't do that. Have you tried loading the lens profile?
WARNING: I often dispense advice in fields I know little about!
1,989 views & 0 likes for this thread, 8 members have posted to it.
1461 guests, 131 members online
