Thread started 17 Oct 2014 (Friday) 20:40
7D2 noise question
bettyn
Oct 17, 2014 20:40 |  #1
Have had a 7D for several years now and love the camera. Since my copy is having problems and probably will have to be sent to Canon for repair, I am considering upgrading to a 7D2. Was wondering if the noise factor is better on the 7D2, as this is my one complaint about the 7D.
Any info available on this?
My Gear: 6D, 7D, EOS-M w EF-M 22 f2 STM and EF-M 18-55 f3.5-5.6 IS STM, 17-40L f4, 24-70L f2.8, 100 f2.8 non-IS macro, 70-200L f/4 IS, 400L f5.6,, Canon 1.4x II TC, Canon Speedlite 430 EX II, Better Beamer. Manfrotto carbon fiber tripod, 2 monopods, Manfrotto ballhead and pistol grip tripod heads.
olafs ­ osh
I am a nice and fluffy dude
Gallery: 146 photos
Best ofs: 5
Joined Apr 2012
Oct 17, 2014 20:48 |  #2
as I just started a topic on 7D as well, hehe...
are you talking about the ISO and camera's capability in low light conditions? 7D2 has better capabilities for sure. Let's be honest here - 7D is **** in high ISO. If you tend to need more than... emmm... 800... your wish for an upgrade is just logical. It all depends really. What do you do?
- Olafs Osh
fb (external link) | instagram (external link) | YT (external link)|OLAFSOSH.COM (external link)|
Give us "Street Photography" sub-forum in P.O.T.N. !
bettyn
Oct 17, 2014 20:55 |  #3
osh_sekta wrote in post #17218937 (external link)
Birds mostly. Have a 6D for full frame (landscape ) shots.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Oct 17, 2014 20:57 |  #4
I don't think we've seen enough samples at high ISOs, from competent shooters, to know what the real world, usable results from higher ISOs are going to be from that camera.
I'd be happy if they can eke out enough of an improvement to shoot 1600-3200 without thinking about it; although, I can still happily use those for *most* situations with the current model.
olafs ­ osh
Gallery: 146 photos
Best ofs: 5
Joined Apr 2012
Oct 17, 2014 21:10 |  #5
You need a fast friend for your 6D, that's for sure.
I do not shoot with it, but I have worked with 6D - I cannot imagine this apparatus to work on wildlife [and I am not even talking about the beneficiary crop factor here]. Do you need an upgrade? I guess you will enjoy m2. But I have no idea, how dealers work at your end. If the price is reasonable, you should go for it.
- Olafs Osh
gabebalazs
Bird Whisperer
Gallery: 52 photos
Oct 17, 2014 21:30 |  #6
There are actually a couple other threads where there are quite a few high ISO shots, comparison shots between 7D2 and various other cameras, including the 7D. Teamspeed alone has made a few using RAW files.
SONY A7RIII | SONY A7III | SONY RX10 IV | SONY RX100 | 24-70 2.8 GM | 70-200 2.8 GM | 16-35 F/4 | PZ 18-105 F/4 | FE 85 1.8 | FE 28-70 | SIGMA 35 1.4 ART | SIGMA 150-600 C | ROKINON 14 2.8
Gabe Balazs Photo (external link)
Nature Shots Portfolio (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 17, 2014 21:34 |  #7
1. If you cannot shoot higher than iso 800 on the 7d, you are most likely doing something wrong.
2. As the 7d2 is maybe 2/3 stop better than the 7d, then you won't be able to go above 1600 on the successor.
That is being honest. ;)
olafs ­ osh
Gallery: 146 photos
Best ofs: 5
Joined Apr 2012
Oct 17, 2014 21:52 |  #8
You cannot shoot past ISO800 without additional lights to get good results. Of course, the setting and the actual need for this and that can change this, but, in my opinion, past this line iso do start to play pretty significant role and too often it limits you. i surely do not want to compare it to anything, becouse it's pretty pointless - just get a different cam - just stating, that overall at this point is reached some sort of limit.
- Olafs Osh
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 17, 2014 22:19 |  #9
Expose properly and even a bit to the right and you can get at least 2 more stops. Show me a raw where you tried a higher iso, and I believe I can point to what the issue was, camera, settings, or otherwise.
BG ­ Ed
Joined Feb 2012
Oct 17, 2014 22:19 |  #10
Check out this guy's write-up. Yes, he is a Canon ambassador, but I like his honesty and how straightforward he is. He comments on ISO, noise, and bird shots.
http://www.naturephoto​graphyblog.com (external link)
GeoKras1989
Joined Jun 2014
Oct 17, 2014 23:55 |  #11
If you don't like the 7D at 800, you won't like any other camera at 1600. The 7D is quite capable of good results at 6400, and excellent at 3200. My 60D has the same sensor and I've got framed 8x10s hanging that were shot at 6400. If you don't like what you get out of a 7D at 800, it is nothing the camera is doing wrong. Look at some of the high-ISO threads.
The 7D2 will be an insignificant upgrade with regard to noise. It is still an apsc sensor.
WARNING: I often dispense advice in fields I know little about!
Weja
Gallery: 1115 photos
Best ofs: 7
Joined May 2011
Oct 18, 2014 01:21 |  #12
GeoKras1989 wrote in post #17219114 (external link)
If you can post one good 6400 example in the 7d thread i believe you.
bw!
Canon gear::arrow: R5 , 600mm. F4 L IS II , RF 100-500, EF 100 F2.8 L IS macro, 1.4 Tc.III .
Gitzo 3542 LS with Wimberley head II , centre column with Gitzo ballhead.
GeoKras1989
Joined Jun 2014
Oct 18, 2014 01:45 |  #13
Weja wrote in post #17219161 (external link)
bw!
Oh, please! Don't take my word for anything. I am just an amateur trying to get the most out of my camera. There are hundreds of other folks doing the same. See this thread:
https://photography-on-the.net …?t=1308983&high​light=3200
I am sure if you spend any amount of time looking, you could find thousands of examples of high-ISO photographs that look good.
Added:
Here is a snap (first shot) I just made in my kitchen. ISO 102,400. Loss of detail, sure. Obliterated by noise? Hardly. As the 7D is known to be less than two-stops below the 6D in ISO performance, this is about what the 7D can do at 25600, if it could go that high. The 7D at 12,800 would be noticeably better than this. Anyone who claims you can't use a 7D above 800 is completely delirious.
Added, later:
I figured you wouldn't believe a photo from a 6D is relevant to what a 7D/7D2 could do. This (second shot) is from a 60D (same sensor as 7D) at 12,800.
Philihase
Gallery: 52 photos
Joined Dec 2013
Oct 18, 2014 02:06 |  #14
I honestly dont know if this is a good example or not of iso 6400 on a 70D (which most people seem to think is a similar sensor to the 7D2) and I am sure that people that are good in PP could get more out of it. But I was quite happy how it turned out.
IMAGE: https://farm4.staticflickr.com/3843/14541971133_5c4032d98f_b.jpg
IMAGE LINK: https://flic.kr/p/oa2p​oe  (external link) IMG_1486 (external link) by Philihase (external link), on Flickr
https://www.facebook.c​om …e-Photos-852961268075109/ (external link)
GeoKras1989
Joined Jun 2014
Oct 18, 2014 02:26 |  #15
Philihase wrote in post #17219189 (external link)
I see lots of feather detail and no distracting noise. I'd be happy with that.
7,061 views & 0 likes for this thread, 14 members have posted to it.
7D2 noise question
926 guests, 117 members online
