Thread started 20 Oct 2014 (Monday) 21:47
Input wanted
mdaddyrabbit
Oct 20, 2014 21:47 |  #1
What is your input on this image?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/10/3/LQ_697826.jpg
Image hosted by forum (697826) © mdaddyrabbit [SHARE LINK]
Website (external link)
CANON
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Oct 20, 2014 22:02 |  #2
I would crop it a bit tighter. And maybe warm up the background just a bit but overall its a very nice image.
Fitness ­ Freak
Gallery: 13 photos
Joined Nov 2011
Oct 20, 2014 22:32 |  #3
At first glance I liked it quite a bit, but once I looked at it for a few seconds longer, it looks like the family was photoshopped onto the background. I'm guessing maybe you made a layer and blurred the background, but it looks a little too obvious for me. I do like the background itself and the concept you were going for though. All that said, it's just my opinion.
FYI: "Fitness Freak" is also known as "Amber" outside of POTN.
http://fineartamerica.​com/profiles/1-amber-kresge.html (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 20, 2014 22:36 |  #4
They look pretty good, but the grass under their legs looks way too sharp.
beano
Oct 21, 2014 05:58 |  #5
They also have a blurry halo around them. Try and keep the grass sharp along the focal plane too. I think you're really close here, just need a little more work. ;)
Scott
Naturalist
Adrift on a lonely vast sea
Oct 21, 2014 06:42 |  #6
Good initial look but then a few seconds later I notice "Ghosting" around them. What happened?
5D Mk IV & 7D Mk II
EF 16-35 f/4L EF 50 f/1.8 (Original) EF 24-105 f/4L EF 100 f/2.8L Macro EF 100-400 f/4.5-5.6L[/FONT]
mdaddyrabbit
Oct 21, 2014 07:46 |  #7
I didn't have my settings right in camera so my background was not blurry. I tried to do that after the fact!
CANON
Numenorean
Oct 21, 2014 09:11 |  #8
mdaddyrabbit wrote in post #17224898 (external link)
You can tell on the grass between the legs.
Next time stand farther away and use a longer focal length. You'll get more background blur with the same f-stop. The longer focal length will be better for your subjects as well as you have less distortion. It's not bad here but I would have filled the frame a bit more with the family and then you might notice more.
Qbx
Gallery: 52 photos
Oct 21, 2014 09:48 |  #9
A more natural blur is possible by creating a separate layer of the background (mask out the people), blur it, then fill its layer mask with a graduated filter from bottom to top black to white. Then the blur will become progressively increased from the start to the top of the filter range.
-- Image Editing OK --
travisvwright
Gallery: 21 photos
Joined Feb 2013
Oct 21, 2014 09:54 |  #10
Well that's exactly what it looks like. Try Qbx method for adding a more natural blur.
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
Hannya
Oct 21, 2014 13:12 |  #11
Potentially a nice pic except that bright sky shape top centre distracts. Its always tricky trying to fake background blur. If you can be bothered, select the group and some of the foreground and copy to another layer. Then dup the background and use lens blur, but not too heavy. Then use a grad layer mask to blend the foreground with the new blurred background. Then put the group on top and 'slightly' transform to enlarge to cover the spread of the blur from the background. Either that, or cut them out, then use content aware to fill the void. Do it properly in camera next time. Saves a massive amount of pfaffing around ....
“Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
Sports Pics (external link)
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Oct 21, 2014 13:52 |  #12
This shallow DOF is a good look to go for, but it is near impossible to recreate properly in PP, I know I've tried! Do you have a fast (f/2.8 or less) lens? It takes more effort to learn to use, but the results are often gorgeous.
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
mdaddyrabbit
Oct 21, 2014 19:57 |  #13
I shot this with a Canon 60D and a Sigma 17-70mm 2.8 IS
CANON
randizzle
Oct 22, 2014 08:12 |  #14
The first spot I noticed was between the man's shoulder and the woman's hair. Then I noticed the same thing in between all of their legs. What does the original look like?
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Oct 22, 2014 08:55 |  #15
mdaddyrabbit wrote in post #17226190 (external link)
At 23mm f4.5 you are not going to get a very shallow DOF. I wonder if you might do well to get a prime lens e.g. 50mm f/1.8. If you are really keen get a Samyang 85mm manual lens - it is a lot harder to use, but, with practice, you can get great portraits with nice bokeh.
4,711 views & 0 likes for this thread, 14 members have posted to it.
Input wanted
1511 guests, 131 members online
