Hi,
I have two monitors. I set them up and then used my i1Profiler to calibrate both monitors. Then I started working on a black and white image in LR. I had the same image opened on both monitors and I noticed they were different colors! After some VERY extensive subjective testing I figured out that the right side of monitor #1 is significantly bluer than the left side/middle. Monitor #2 appeared to my eyes more even, and in general warmer than monitor #1.
I recalibrated both monitors like 5 times each. I also tried different settings of contrast, and tweaked the RGB values extremely carefully during manual adjustment. I am pretty sure I did the calibration correctly.
So... then I got an idea. I started up the profiler but when it got to the RGB adjustment phase, it also shows temperature. So, I used that to measure the temperature of different regions of the monitors:
Monitor #1:
middle 6526
top 6400
bottom 6660
left 6594
right 6656
Monitor #2:
middle 6616
top 6300
bottom 6885
left 6756
right 6558
Note: both "middle" values were very near 6500 from the previous calibration, so that's kinda weird to me already.
So, ...I am thoroughly confused. Monitor #1 does measure to be colder on the right. However, monitor #2 has much more variation left to right, and that's not what my eyes see.
Anyway, does anyone know if the variation in temperature across the different areas of the surface is within tolerance of a mid/high-end 99% Adobe monitor?
I'm wondering if I should ask for my money back? I mean, personally, I can clearly see that the BW picture I was editing is bluer on Monitor #1's right compared to Monitor #2's left. (And again, the measurements don't indicate that--wtf? I suppose that could be explained because I calibrated from center, and maybe the end result is a colder monitor #1?)
