Thread started 20 Feb 2006 (Monday) 22:42
Display problem/DVI Cable
CanonLaw
Joined Jun 2005
Feb 20, 2006 22:42 |  #1
Hey, I had been wanting to purchase a DVI cable for my 19" flat panel for a while now, and I figured it might improve image quality for editing as well. Well, not I get these weird flashing pixels when I open pictures. It doesnt really affect the picture quality, but it is rather annoying. Has anyone experienced this before? Thanks!
tim
Light Bringer
Feb 21, 2006 02:33 |  #2
I run my Samsung 19" LCD from an nVidia card with a DVI cable, i've never seen anything flash that shouldn't.
DavidW
Feb 21, 2006 07:07 |  #3
Flashing pixels is abnormal. You could try reversing the cable (just in case one of the connectors doesn't make well one way round) or - more likely to be the issue - updating your graphics card drivers.
It may be that the DVI part of either your graphics card or monitor is bad.
David
CanonLaw
Joined Jun 2005
Feb 21, 2006 10:29 |  #4
Thanks for the input. I have an NVIDIA card as well. I updated the drivers and it seemed to help for a while, but then the problem came back. I just decided to use a standard VGA cable instead because I tried that and it works fine.
One question though...in the process of editing photos on an LCD screen, am I losing out by using the analog cable?
DavidW
Feb 21, 2006 11:07 |  #5
Something is wrong if you can't get DVI to work - I have a DVI connected panel to an nVidia card and it's rock steady.
You are lowering the performance of the screen somewhat by using a VGA cable - you may find there is some noise and bleed between pixels that DVI would avoid.
I'd try exchanging the cable - it's just possible that it's faulty somehow.
David
809 views & 0 likes for this thread, 3 members have posted to it.
1724 guests, 103 members online
