Thread started 24 Oct 2014 (Friday) 17:35
Magnification calculation
iroctd
Joined Aug 2013
Oct 24, 2014 17:35 |  #1
Hello all, finally got my setup complete for doing macro and I wanted to check to see if I was calculating my magnification correctly. I'm using a Canon T5i, sensor width of 22.3mm and (by the picture) I can fill the frame with 8mm on a ruler.
So 22.3 / 8 = 2.7875
Would this be correct?
-Feedback-
EOS_JD
Oct 24, 2014 18:33 |  #2
What lens are you using?
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
EOS_JD
Oct 24, 2014 18:35 |  #3
the 100mm Macro has 1:1 lifesize. This means something the same size as your sensor or film fills the image.
All My Gear
EOS_JD
Oct 24, 2014 18:37 |  #4
Your only option for greater magnification than 1:1 would be extension tubes, or perhaps the Canon MP-E 65mm f/2.8 1-5X
All My Gear
iroctd
Joined Aug 2013
Oct 24, 2014 18:38 |  #5
Yes the 100mm macro, 62mm of extension tubes and a 1.4x converter.
-Feedback-
CyberManiaK
Oct 25, 2014 00:15 |  #6
iroctd wrote in post #17231565 (external link)
Yeah according to your picture your math is correct.
Carlos
60D / 10-20 + 100L + 40/2.8
iroctd
Joined Aug 2013
Oct 25, 2014 06:35 |  #7
Thanks so much!
-Feedback-
1,917 views & 0 likes for this thread, 3 members have posted to it.
1106 guests, 110 members online
