Thread started 25 Oct 2014 (Saturday) 13:10
Storage workflow ideas
jaomul
Joined Apr 2011
Oct 25, 2014 13:10 |  #1
Not sure if this is correct section but suppose storage for processing is related so here goes=
I just got a new laptop. I am not as organised as I should be with my photos. I am not a pro, just enthusiast but would like to have a good system so I know where everything is.
I think i should put raws in a raw folder, jpegs in a jpeg folder and edits in an edited folder, backing up raws on a portable hard drive, but raws may fill my computer fairly fast.
What do you guys do? I'd like to have a better system of organising. Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
mike_d
Oct 25, 2014 13:17 |  #2
This is why I use Lightroom. Everything gets imported into Lightroom which saves the raw files to a folder structure. Inside Lightroom, I apply keywords and organize photos into collections. This makes it easy to find photos later. I maintain a folder structure (mirrors my collections) of developed jpgs I've outputted from Lightroom for easy viewing by others in the house.
If you don't have enough space on your internal hard drive, you can always use an external. I use a Synology NAS for this reason. The lightroom catalog and the folder with all the raws gets backed up regularly.
tim
Light Bringer
Oct 25, 2014 14:19 |  #3
For my personal work I have a folder for year, then month, then shoot or event name. If I want to find something I just search for the folder. I don't tag.
I have a separate folder (with the same year/event subfolders) of the jpeg files I want to share. I use this tree to generate my photo website.
bildeb0rg
Gallery: 821 photos
Nov 02, 2014 05:08 |  #4
Years ago I borrowed Tims' method (post processing and print guru btw) of YY-MM-DD-Event for RAWS then I usually create a sub folder within that one for small jpegs to post to web. Once uploaded they are deleted.
Printed jpegs are saved in folders named with the print size I.e. 10"x8", 16"x12" etc.
The only thing I back up are the RAWS as jpegs can always be regenerated, usually with better results as my post skills improve.
BigAl007
Gallery: 556 photos
Nov 02, 2014 05:40 |  #5
I'm another who uses LR to organise my images. I would really recommend a system that uses database tools to organise images. I used to keep all my images in dated folders, but eventually you need something more. The hardest bit was going back and doing the keywording for all the old images. LR makes it really easy to apply keywords on import, so I add all of the simple stuff like event details in bulk while importing the images. For my aviation subjects for example I will then go through and add image specific keywords, such as aircraft type. Although this may take a bit of effort it is quite possible to do a full airshows worth of images in a hour or two, even when I may have in excess of 1500 images. Adding the keywords to multiple files is as easy as a single file, so you usually only have to do a dozen or so groups. In other situations, where that level of keywording is overly complex the images may not get additional keywords added. I also make use of IPTC subject codes, as LR can also make use of them.
Once I have tagged images LR offers many different ways of sorting images. You can make collections of images manually by simply draging and dropping, what is good, and beats just using the file structure, is that the same images can be in as many collections as you like. LR also feature virtual copies, so you can also have more than one version of the image, with only minimal extra data storage, you don't have to copy the original file. As well as manual collections LR has Smart Collections, which a made up of stored searches, which allows you to group the images by pretty much any detail stored in the images EXIF data. You can also have collections of collections. Of course you can also sort manually from anywhere within the Libary module to further refine your visible images.
I use LR so know its features well. There are other similar database systems avilable, if you do not want to use LR. I just cannot give you details.
Alan
1,095 views & 0 likes for this thread, 5 members have posted to it.
910 guests, 118 members online
