Both are good, which one do you all have and why? It seems that everyone uses the 1.4. I just received my EF 2 II and will put it to work in the next few days. Just wanted to know.
TIA,
Lynn
Feb 21, 2006 04:55 | #1 Both are good, which one do you all have and why? It seems that everyone uses the 1.4. I just received my EF 2 II and will put it to work in the next few days. Just wanted to know.
Feb 21, 2006 05:00 | #2 I don't use either but I think the x1.4 is better/more popular with those long slow lenses because the x2 has a bigger fstop effect. Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images
LesterWareham Moderator More info | Feb 21, 2006 05:06 | #3 I suspect it depends more on the quality of the lens you have used it with. Good zooms and most primes will probably be fine with the 1.4X but only the sharpest primes will hold up well with a 2X. Gear List
Thanks to both of you. I plan on using it on my 70-200L F2.8 and the 100-400L F4.5 only. I'll give it a go.
JackW. Senior Member 841 posts Joined Jun 2003 More info | I have both. The 1.4 on my 300f/4L IS is terrific. 20D, 30D, 500f/4L IS, 300f/4L IS, 300f/2.8L IS, Canon 1.4TC, Canon 2xTC, 70-300IS, 17-85IS, EFS 10-22, Sigma 150 Macro, 3021PRO, RRS BH-40LR, Gitzo 1325, full Wimberley Head v2, Wimberley Sidekick, and a bunch of other stuff.
Jack W. wrote: I have both. The 1.4 on my 300f/4L IS is terrific. I just got the 300f/2.8L IS and the 2x. I've only had a chance to take some quick test shots with this combo (lousy weather since I got it-figures heh heh), but those shots looked great. I've also seen shots posted by others, and they were beautiful. Jack Thanks Jack
LesterWareham Moderator More info | Jack W. wrote: I have both. The 1.4 on my 300f/4L IS is terrific. I just got the 300f/2.8L IS and the 2x. I've only had a chance to take some quick test shots with this combo (lousy weather since I got it-figures heh heh), but those shots looked great. I've also seen shots posted by others, and they were beautiful. Jack From the MTF data the 300/2.8 is a very very sharp lens. Canon show the MTF for the two teleconvertors for compatible lenses in the Eyes of EOS book. The 300/2.8 holds up to the 2X much better than most. Gear List
| Latest registered member is semonsters 1607 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
