glasllyn wrote in post #17236074
Thank you for that. Very helpful. I don't use PS, so some of that is lost on me, unfortunately. It would be great to have that info tailored to Lightroom users.
This will depend on how you are exporting the image from LR. If you are simply going to process the image and use the normal export dialogue then it becomes quite simple. First crop the image to match the aspect ratio of the print. If the ratio you need is not in the list of ratios in the crop drop down, then enter it as a custom size. All of the other settings are done in the export dialogue. In the File settings section set the colour space to sRGB (which is the usual LR factory setting), unless the lab has told you to use a different colour space setting. Use JPEG as the file type and set the quality setting to 80.In testing there is no visible difference in the file, that I could measure using Photoshop, between using a Q100 setting and the Q80, although the file is about 40% smaller.
Then you will need to move on to the Image Sizing section. Again this is actually pretty simple. Tick resize to fit, select Width and height, and then select either In or cm instead of pixels. This will ensure that the image is output at the correct size for the resolution of the output device/printer. In the resolution box set the resolution to match whatever the lab has told you it needs for the printer, or just set it to 300. In the sharpen section you have the option to add output sharpening. I usually use it, and would set it for the outptut type that is most suitable, Gloss paper for glossy prints, matte apaer for everything else, unless you are only viewing the file on screen, but here we are talking about files for printing. Personally I set the Amount to high, but that is personal preference. There is no way to preview output sharpening, as to apply it for viewing, the file conversion has to be done anyway.
Once you have set this up of course you can save it as an Export preset to enable you to reproduce the settings instantly when you need them again. If you use the Print module to do your printing from, all of these settings are also there, The only real issues if you are sending out to a print lab, is that you need to set some settings in a print driver, if you do not have a printer, or your printer driver doesn't support certain custom settings, then I suggest using a PDF printer, most simple PDF printer drivers allow you to customise all of the settings that you might need. mostly that is paper size. If you are doing ab prints at sizes that your desktop printer might not support this is the way round it, while using the print module. You will need to set the module to print to file, after which if you have a look at the various settings in the right side tool bar you should be able to find all of the settings that I have mentioned above. The print module will allow you to see a preview of how your print should look, but it is a little harder to use.
Alan
