Thread started 27 Oct 2014 (Monday) 14:57
How do I trigger a rebel from a pocket wizard?
Village_Idiot
GREATEST POTN MEMBER EVER
Oct 27, 2014 14:57 |  #1
I'm Borrowing a Rebel for a photo booth and need to trigger it via a Pocket Wizard. It's a fairly new rebel and has a miniphone looking remote port. Can I just use a 3.5mm to 3.5mm cable? Will it fit and will it work? I only need it one night for a friend's anniversary party, so I'd like to not have to go buy some expensive proprietary cable if I can help it.
My village called. I was told that they missed me.
Speedotron users, untie!
Echo63
Oct 27, 2014 22:16 |  #2
Village_Idiot wrote in post #17236099 (external link)
pretty sure the rebel cable is 2.5mm, not a standard 3.5mm audio connector (at least my 350D is)
you need to make sure the correct pins are connected too, its easy enough to make a cable if you can use a soldering iron (i made my own pre trigger cable for a rebel, then later hacked a cable release to build one for a 1D)
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
Village_Idiot
Oct 28, 2014 05:41 |  #3
Echo63 wrote in post #17236804 (external link)
Thanks for the info. I just ended up paying $25 to have a PW cable shipped to my house by Thursday. Do the 7Ds use the same cable?
John ­ from ­ PA
Joined May 2003
Oct 28, 2014 08:31 |  #4
Village_Idiot wrote in post #17237158 (external link)
It is possible to research this yourself. I'd start by downloading the manuals from Canon's website and making a comparison of the accesories. Since it appears you aren't familiar with either camera, the manuals will also likely prove helpful on setup.
Village_Idiot
Oct 28, 2014 08:40 |  #5
John from PA wrote in post #17237357 (external link)
It is possible, but I figured the friendly people here might have been able to help.
tnguyen600
Oct 28, 2014 08:43 |  #6
Can you share your photobooth set-up? I've been researching this for the past year and I'm always curious how other photogs are doing it.
I have two open style set-ups. For my one set-up, I have everything enclosed in frame and covered up with white translucent paneling. For my other set-up, I have a T4i with ABR800 on a tripod connected to a laptop and an HDMI cable going into a 39" TV. Crowd pleaser. In either situations, the session is initiated by hitting the button or space bar (depends on my set-up).
How are you using the PW?
www.tvnphotography.com
Village_Idiot
Oct 28, 2014 09:05 |  #7
tnguyen600 wrote in post #17237374 (external link)
Mine isn't that advanced. I'm going to have the camera set on a tripod with a Dynalite head in a beauty dish positioned above the camera. The pocket wizard will be mounted somewhere with a big "PRESS HERE" label on it. It'll start the timer on the camera and then take a picture. There's not going to be a review screen or anything. All the photos are going to go in a FB group of the people at the party or to the Anniversary couple. It'll be a small group of friends and people we all know, so it won't have to be set up to print like a real photo booth.
1,678 views & 0 likes for this thread, 4 members have posted to it.
517 guests, 156 members online
