Thread started 31 Oct 2014 (Friday) 20:58
Canon 6D's synch speed with PW and AB
hoaindao
Gallery: 33 photos
Oct 31, 2014 20:58 |  #1
So I just obtain a couple of PW plus III along with 2 AB1600. Using it with my 6D, i'm getting a dark line when shooting at shutter speed of 1/200th. Going down to 1/160th, the photos looks fine. Specs on the PW and AB seems to acommodate 1/200th shutter speed. Is it my camera then that's not able to synch that high?
5DIII - 35L - 85L II - 135L - Sigma 70-200 2.8 OS - 480 EXII - AB1600 :)
mainbyte
Joined Mar 2011
Oct 31, 2014 21:06 |  #2
The 6D synch speed is 1/180th. That speed probably only works with canon flashes (or a good clone). With studio strobes the 1/160th would be about right, would depend on the studio strobe, and you may even have to go lower.
Ron
Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
NewCreation
Gallery: 47 photos
Joined Jan 2013
Oct 31, 2014 21:07 |  #3
Yes, it's the camera. Max sync is 1/180 or 1/160 when you're in 1/3 stop increments.
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
hoaindao
Gallery: 33 photos
Oct 31, 2014 22:49 |  #4
Thanks all. I guess I will have to live with it then.
Photo123abc
Joined Dec 2012
Nov 03, 2014 04:15 as a reply to  @ hoaindao's post |  #5
I can shoot 1/4000s with Pixel King triggers and 320EX flash so its not the camera. Its probably your flash that cant keep up? Or have you enabled HSS via camera menu / triggers or whatever you do to get it enabled?
You are what you eat - I dont remember eating a photographer.
dedsen
Nov 03, 2014 21:08 |  #6
Photo123abc wrote in post #17249076 (external link)
There is no such thing as HSS on an AB studio flash. That is a Canon Speedlite thing.
Photo123abc
Joined Dec 2012
Nov 05, 2014 09:43 |  #7
dedsen wrote in post #17250690 (external link)
Anyhow its not the camera. It can do alot faster that 1/160th.
mainbyte
Joined Mar 2011
Nov 05, 2014 10:07 |  #8
Photo123abc wrote in post #17253625 (external link)
Well, a bit faster, the sync speed for a canon 6D is 1/180.
Here is the info from the 6D manual:
IMAGE: http://mainbytephotos.com/potn/sync.jpg
Ron
gnome ­ chompski
Joined Jun 2013
Nov 05, 2014 10:15 |  #9
he's referring to high speed synch. Activate this on a flash that has this feature and you can do much faster than the normal synch speed.
Tumblr (external link)
Instagram (external link)
mainbyte
Joined Mar 2011
Nov 05, 2014 10:35 |  #10
gnome chompski wrote in post #17253677 (external link)
Read Dedsen's reply above. Of course you can use HSS with a canon flash (or clone), but AB's do not have this feature.
Ron
gonzogolf
dumb remark memorialized
Gallery: 208 photos
Nov 05, 2014 10:35 |  #11
Do you understand how the shutter works? 1/180 is the fastest speed the shutter is completely open for s flash to expose the entire sensor.Any faster and the shutter begins to close before it fully opens. HSS allows a flash to pulse insread of flash so it behaves as if its a continuous light source. Thats a speedlite thing. Certain triggers can fool the timing of studio strobe so that it fires early but the flashtube glows at a lower power for a brief time so that it can be used similar to HSS. That technique is called hypersync or supersync by different manufacturers. But you are dead wrong about the limitations being in the camera.
The PWIII triggers do not support HSS or hypersync snd the tail burn on the alien bee lights is short making them difficult to use in that mode if the OP had the right trigger.
gnome ­ chompski
Joined Jun 2013
Nov 05, 2014 16:39 |  #12
mainbyte wrote in post #17253725 (external link)
Ron
LOL, oh yea...apologies:oops:
dedsen
Nov 05, 2014 19:17 |  #13
You might want to give up on strobe and camera sync speed advice. You are really not helping with misinformation.
3,146 views & 0 likes for this thread
Latest registered member is Peace Train
812 guests, 187 members online
