Thread started 02 Nov 2014 (Sunday) 12:38
Slow focus in low light - what do you do?
drmaxx
Gallery: 41 photos
Nov 02, 2014 12:38 |  #1
I was asked to take some pictures at a family event. Indoor and moodily lit - so not much light. I am using a 60D and a 35 or 50 mm with an on-camera flash. The goal are candids - mainly memories for the organisers.
However, at low light autofocus is sometimes painfully slow. Is that the camera? How do other people deal with this issue?
Donate if you love POTN
jcolman
Gallery: 17 photos
Nov 02, 2014 13:30 |  #2
Does your flash not have focus assist?
www.jimcolmanphotograp​hy.com (external link)
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Nov 02, 2014 13:33 |  #3
See above, by far the easiest solution. If it hasn't then you can always shine a pen torch to help the camera focus (use one shot).
Fujifilm cameras and lenses.
Gear I use to create (external link)Instagram (external link)Blog (external link)
Coffee & Fujis (external link)About Capture One (external link)YouTube (external link)
tim
Light Bringer
Nov 02, 2014 13:47 |  #4
Make sure your camera is on one shot AF, not continuous focus, so the AF beam of the flash fires. Make sure you're using single centre point focus, and put it over an area of high contrast - black/white ideally, but anything with detail is fine - an eye, not a blank wall.
maverick75
Joined May 2012
Nov 02, 2014 14:04 |  #5
I'm with Tim, it's most likely your camera settings and finding contrast. I even shot a event with my EOS M the other day with no issues, and the focusing on that is horrendous compared to the 60D.
drmaxx
Gallery: 41 photos
Nov 02, 2014 14:07 as a reply to  @ tim's post |  #6
The flash is a 430 (there is somewhere an EX and a II) - I believe it has a focus assist? At least the camera is focusing correctly. But is slow for candids. I usually use F1.4 to F2.8 depending on the number of people in the picture.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Nov 02, 2014 14:10 |  #7
What 50mm are you using? The 1.8 will be slow.
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
mclaren777
Joined May 2012
Nov 02, 2014 14:35 as a reply to  @ jcolman's post |  #8
Focus assist is the red pattern that the speedlite shots into the scene.
HTTP response: NOT FOUND | MIME changed to 'image%2fjpeg'
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
jcolman
Gallery: 17 photos
Nov 02, 2014 14:46 |  #9
drmaxx wrote in post #17247999 (external link)
Not to derail this thread but shooting group shots at f/2.8 is a good way to have some people out of focus.
mike_d
Nov 02, 2014 15:30 |  #10
NewCreation wrote in post #17248004 (external link)
I have the 50/1.4 and its not so great focusing in low light either. I've used (but don't own) the 35L and 50L and found them to be pretty slow focusers in general. My current favorite for low light AF performance is the 24-70 f/2.8 II. It really seems to take advantage of the dual-cross type AF points on my 5DIII in a way that faster, but older, lenses can't.
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Nov 02, 2014 16:14 |  #11
You find the 50 1.4 slower then the 24-70 2.8 to lock focus? Gona' have to check one out soon. I'd have thought that, in low light, @1.4 the light getting to the sensor would have made the difference over the 2.8 even though the 50 is slower focus.
mike_d
Nov 02, 2014 16:22 |  #12
Two Hot Shoes wrote in post #17248195 (external link)
You'd think so, but I found the 24-70 2.8 II superior. I believe a wider aperture only helps up to a certain point and the 24-70 is just a faster focuser in general. Both are Group A lenses for the 5DIII which means they take advantage of the 5 dual-cross type AF points in the center.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Nov 02, 2014 16:45 |  #13
mike_d wrote in post #17248125 (external link)
I'm confused...are you having trouble with the 5diii, as well as the 60d? I think an af assist beam is your solution. I am shooting with a 60d and 6d for wedding receptions and the af assist beam is what works for me and I am not using anything as stellar as the 24-70ii. I am using a Tamron 28-75 and usually my 85 1.8.
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Nov 02, 2014 16:48 |  #14
Thanks for the info Mike.
drmaxx
Gallery: 41 photos
Nov 03, 2014 14:29 as a reply to  @ Two Hot Shoes's post |  #15
Need to test my set-up and focus on the af assist beam. There might be something wrong or I am not using the flash correctly.
Thanks for all your reply's.
2,535 views & 0 likes for this thread, 8 members have posted to it.
1130 guests, 168 members online
