Thread started 03 Nov 2014 (Monday) 13:33
Blacks crushed in sRGB on Mac? Read this.
kirkt
Nov 03, 2014 13:33 |  #1
Hi folks,
I have been struggling with a persistent problem on my Mac Book Pro, running Mavericks 10.9.5.
The basic problem is that when I edit an image with very subtle and dark shadow detail, convert it to sRGB for web display and then view the image in Preview or Safari, the blacks are crushed. If I view the sRGB image in Photoshop, no problem.
I started digging around and found these very informative posts:
http://lagemaat.blogsp​ot.com …gement-bug-in-mac-os.html (external link)
and
https://forums.adobe.c​om/message/6027420 (external link)
It turns out that Lightroom users in Mavericks and apparently Yosemite (I have not upgraded) are reporting the same issue, but only in the Develop module (but not in the Library module) of Lightroom.
(EDIT: I opened the below images in Lightroom - they are BOTH DISPLAYED INCORRECTLY - blocked shadows, etc. - in the Develop module.)
I thought I was nuts, I re-calibrated and profiled my displays, checked RGB numbers and histograms, etc. etc. I may be nuts, but apparently not for the reason associated with my shadow tones getting crushed.
As speculated in the blog post to which I linked above, this appears to be a Mac/Safari (Preview?) issue. There are a couple more posts from the above blog that deal with this issue, including this one:
http://lagemaat.blogsp​ot.com …ication-of-mavericks.html (external link)
which quantifies the problem. I did similar experiments and came to the same conclusion. Crazier still is the fact that Firefox and Chrome render the sRGB tagged image correctly. Similarly, if one converts the sRGB image to AdobeRGB, the problem disappears and blacks are rendered correctly.
So, be wary if you are using Safari to view sRGB content and it seems as if your shadow tones are getting crushed. I have been trying to find a viable solution for posting my embedded images in AdobeRGB - Dropbox Public folder links will permit you to embed an image with any tag you want, as opposed to most photo sharing/hosting sites which strip the tag out or assume sRGB.
Here is a test image to see if you are affected with the issue. The top image is sRGB, the bottom image is AdobeRGB. You obviously need a color managed browser to view these images properly - they should look identical, more or less.
The number below each patch represents the sRGB R, G, B value (that is, "1" means a patch with sRGB R,G,B triplet of (1,1,1). On my display, in Photoshop, (and Chrome and Firefox) I can differentiate down into the "2" level. On Safari, the first row is more or less completely black and I can barely differentiate between adjacent patches in the second row.
Hopefully most of you will read this post and say to yourself "I can't see a difference - what the hell is he talking about?"
kirk
sRGB
IMAGE: https://dl.dropboxusercontent.com/u/78890747/Patches_sRGB.jpg
AdobeRGB
IMAGE: https://dl.dropboxusercontent.com/u/78890747/Patches_aRGB.jpg
Kirk
kirkt
Nov 03, 2014 13:41 |  #2
Mac users, please post your experience with this here. I do not use Lightroom very often and, when I do, it is with raw images, not RGB images tagged with a specific color profile.
Thanks,
kirk
Kirk
kirkt
Nov 03, 2014 14:02 |  #3
Note - I was using LR 5.4 for mac. I am currently updating to 5.6 and will report back when I update - for some completely crazy reason, the download is over 500MB. Wow.
kirk
Kirk
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Nov 03, 2014 14:47 as a reply to  @ kirkt's post |  #4
I am running Firefox v. 32.0.3 with color management enabled on OS X 10.9.5, viewed on a NEC PA272 monitor calibrated with i1 Display Pro. As you state, I can differentiate to patch 2, although it is a little plugged. It is the same for both versions.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
tonylong
...winded
Gallery: 60 photos
Nov 03, 2014 15:00 |  #5
[QUOTE=kirkt;17249852]​Hi folks,
and
kirk
sRGB
Heh!!!:)!!!
Tony
kirkt
Nov 03, 2014 15:23 |  #6
ThreeHounds wrote in post #17250001 (external link)
Try Safari. My guess is you will not be so pleased.
Lightroom (especially the Develop module) is also acting really bizarre, although Adobe have acknowledged this and are apparently working on a solution:
http://feedback.photos​hop.com …clipped_shadows​_under_osx (external link)
(scroll down to the bottom if you are impatient). If you import both images into LR (I am now on v5.6) and view them in the Library they look very similar and, more or less, correct. View them in the Develop module and both look the same and crushed.
Thanks for the feedback.
kirk
Kirk
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Nov 03, 2014 16:37 as a reply to  @ kirkt's post |  #7
Interesting. Imported the files into LR 5.4. They look similar, both in Library and Develop modules, with the sRGB version being a point or two darker reading the histograms. View them in Safari and the sRGB version shows the shadows crushed. This seems to point to an issue with Safari, not OS X or LR though, no?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 03, 2014 16:48 |  #8
Just for comparison, In firefox, Windows:
The SRGB on my Sony aperture grill I can see tonal difference in all of the squares. 1 is clearly darker than 2.
In ARGB 1-3 are (much) harder tell apart, but there is still a slight difference in all 3. 1 and 2 are very close.
CDS' HOT LINKS
J ­ Michael
Nov 03, 2014 17:55 |  #9
Yes I see the difference in Safari (Mavericks, Mac Pro & Apple Monitor).
drisley
"What a Tool I am"
Joined Nov 2002
Nov 03, 2014 18:28 |  #10
I'm the same as CyberDyne Systems on Windows 7, Firefox, using my 2007 Dell IPS panel (same panel that was used in the 20" Apple Cinema Dispays).
sRGB I can see all squares
adobeRGB I can see 3-15 for sure, but 1-2 are hard to notice for sure.
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
tzalman
Fatal attraction.
Nov 04, 2014 03:21 |  #11
A comparison of Kirk's sRGB image as seen on Firefox (fully color managed) and IE (reads embedded profile but does not use monitor profile, instead uses sRGB display):
Monitor: Dell U2311H profiled with Spyder4 Pro
System: Windows 7 x64
Screen captures were assigned the monitor profile, values measured and images then converted to sRGB.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/11/1/LQ_698855.jpg
Image hosted by forum (698855) © tzalman [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/11/1/LQ_698856.jpg
Image hosted by forum (698856) © tzalman [SHARE LINK]
Elie / אלי
tonylong
...winded
Gallery: 60 photos
Nov 04, 2014 13:48 |  #12
Wowser...>
Tony
4,266 views & 0 likes for this thread, 7 members have posted to it.
1454 guests, 131 members online
