Thread started 04 Nov 2014 (Tuesday) 22:01
Ruby-crowned Kinglet
ID ­ rocks
Joined Feb 2012
Nov 04, 2014 22:01 |  #1
Posted the processed version in the Birds forum and had a little critique there so thought I would take the advice and play around with the image a little.
The advice was to back off the saturation of the background a little.
Anyone interested in playing around with the photo is more than welcome. Let me know if I'm cropping correctly for the right composition as well and any thing else.
1. Original
IMAGE: https://farm4.staticflickr.com/3943/15094905543_01a13b05de_b.jpg
IMAGE LINK: https://flic.kr/p/oZTk​w8  (external link) Ruby-crowned Kinglet 11022014 (42) - Version 2 (external link) by Dan R Cook (external link), on Flickr
2. First processed image
Ruby-crowned Kinglet 11022014 (external link) by Dan R Cook (external link), on Flickr
3. Second attempt. I backed off on the luminance and Saturation of Red and Yellow in the Color block and I tweaked the curves function a bit and brushed it away on the bird.
IMAGE: https://farm8.staticflickr.com/7547/15528811328_77a6a8a551_c.jpg
IMAGE LINK: https://flic.kr/p/pEed​Am  (external link) Ruby-crowned Kinglet 11022014 (external link) by Dan R Cook (external link), on Flickr
Dan
Canon 7D II, 70D, T2i, Canon 500mm F4L, Tamron 150-600MM F/5-6.3 Di VC USD, Tamron AF 70-300mm f/4.0-5.6 SP Di USD XLD, Canon Nifty Fifty, Tamron AF 17-50mm F/2.8 Non-VC
Flickr Page (external link)
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Nov 05, 2014 06:09 |  #2
I'd consider:
crop closer to tail top and left.
Some loss of colour on the bird in the last image - I'd bring that back (yellows and red).
#2 background was overwhelming.
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Nov 05, 2014 08:25 as a reply to  @ Martin Dixon's post |  #3
3.
maybe a touch too sharp on the feathers, and i would clone out that little nub of a branch under the bird. As i think Martin is saying, the saturation on the bird in 2 is good but the saturation of the background in 3 is better. Of course, accuracy of the bird's colors is probably the most important thing.
drumsfield
Nov 05, 2014 13:49 |  #4
Then second and third images are way too oversharpened. Personally I would only slightly sharpen the overall image and spot sharpen with a brush needed areas. From there I would bump the curve slightly in the middle and add a very very small hint of saturation.
Canon 5D MkIII | Olympus OM-D | Olympus E-P2 | 16-35L MKII | 24-70L MKII | 70-200L MKII | 85L MKII | EF 50mm 1.4 | EF 100mm 2.8 | 100-400mm L MKII | 20mm 1.7
Feedback and Full gear list
Website (external link)
AZGeorge
Nov 05, 2014 18:53 |  #5
drumsfield wrote in post #17254090 (external link)
+1
Soft images can be much pleasing than attempts to sharpen them.
George
Democracy Dies in Darkness
ID ­ rocks
Joined Feb 2012
Nov 06, 2014 19:48 |  #6
Thanks everyone for the lesson. I will play around with the image more.
One question and maybe I can find this online, but how do you tell when someone over sharpens the image?
Thanks again.
Dan
Gallery: 15 photos
Joined Jun 2011
Nov 07, 2014 07:40 as a reply to  @ ID rocks's post |  #7
over sharpening is generally a matter of making things look unnatural. In this case, the feathers on the bird's neck and back look more like a metal file than soft feathers. This might be due to your over sharpening of the original, or, it might be because you sharpened a large image, then downsized it making the sharpening appear to be over done. I think most folks will give a minor sharpening to the original, then sharpen individual images to the output resolution.
For this image you might look into a gentle overall sharpening and then using a brush to sharpen the tail feathers and area right around the face. Tail feathers because they are almost falling out of focus and the face because it is an important point of interest. You could do something similar with the saturation of the bird vs the background.
also want to say that it is a really nice image, you did a good job.
1,297 views & 0 likes for this thread, 5 members have posted to it.
1596 guests, 137 members online
