Hi all,
Will the autofocus improvements in the 7D2 allow autofocus with the Canon 100-400mm and a Canon 1.4x extender? Does anyone have experience with this combination?
Thanks.
SteveHS Member 65 posts Joined Mar 2010 Location: New England coast More info | Nov 05, 2014 12:42 | #1 Hi all, Steve
Weja Goldmember More info | Nov 05, 2014 12:56 | #2 5.6 x1.4 makes it a F8 lens. Canon gear:
ScottM Goldmember More info | Nov 05, 2014 13:44 | #3 While technically it should work, if the combo is anything like my 5D3 + 100-400L + 1.4x TC, you probably will not be very happy with the results. I prefer to just crop in post processing instead of using a TC with this lens -- I get better image quality and am not forced to shoot at f/8.
2n10 Cream of the Crop More info | Nov 05, 2014 14:00 | #4 I have the Kenko 1.4x TC with my 7D and there is IQ degradation. Unless you are close to your subject so you have it filling a large part of the frame you are probably better off without using the TC. Moving subjects are to keep in focus as the focus gets rather slow. Those travel parallel to the camera can be focused better.
Brian_R Goldmember 2,656 posts Likes: 8 Joined Aug 2010 More info | Nov 05, 2014 14:12 | #5 it depends on what extender you use. for instance the canon 1.4X mkII you lose a decent amount of sharpness but ive been told the newer mkIII is greatly improved
mfunnell Senior Member 375 posts Likes: 11 Joined Jul 2005 Location: Sydney, Australia More info | Nov 05, 2014 14:25 | #6 My very first shot with the 7D2 was with the 100-400L and EF 1.4x III extender. Focus was on the eye using single-point spot focus. It seemed pretty fast to me, and seems sharp enough for my purposes: ...Mike Some digital cameras, some film cameras, some lenses & other kit.
Nov 05, 2014 19:43 | #7 At first, I thought your photo was upside down. Then I realized you're in Australia. All I want is just a little more than I'll ever have.
mfunnell Senior Member 375 posts Likes: 11 Joined Jul 2005 Location: Sydney, Australia More info | Nov 05, 2014 19:59 | #8 philk54 wrote in post #17254712 At first, I thought your photo was upside down. Then I realized you're in Australia. ![]() This is true. And those rainbow lorikeets are acrobatic little beasties. Some digital cameras, some film cameras, some lenses & other kit.
TeamSpeed 01010100 01010011 More info | Nov 05, 2014 20:10 | #9 Since the original question has been answered (yes, the 7D2 will AF that combination), I am interested in how people are not getting good results with TCs? With the 2x on a Sigma 50-500 OS on a 5D3: These are not full sized images downsized, these are partial crops, probably 30-50%. I have had very good luck with TCs, you just have to dial them in separately with AFMA. Past Equipment | My Personal Gallery
2n10 Cream of the Crop More info | Nov 05, 2014 21:01 | #10 I think that it part of my issue with the TC. I don't need MFA bare on the 100-400 but it is needed with the Kenko TC. The TC doesn't report so MFA is sketchy to use. Maybe I'll get the canon 1.4XIII this winter.
Thanks for all the responses. I do a lot of birds in flight, so I'll just have to try it and see how well it works. Steve
timbop Goldmember More info | Nov 06, 2014 18:41 | #12 Scott M wrote in post #17254082 While technically it should work, if the combo is anything like my 5D3 + 100-400L + 1.4x TC, you probably will not be very happy with the results. I prefer to just crop in post processing instead of using a TC with this lens -- I get better image quality and am not forced to shoot at f/8. ^ this Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Pondrader "now I'm no rocket scientist but I do get a shot or two" 16,028 posts Gallery: 2548 photos Best ofs: 5 Likes: 57084 Joined Aug 2012 Location: Minden, Ontario, Canada More info | Nov 07, 2014 06:17 | #13 I can tell you the mark II makes the kenko 1.4 feel almost invisible compaired to the 7d, I had all kinds of focus issues but they are gone with the 7d mark II, I still prefer not to use it but it works so much better on the 7d2. I do have the canon 1.4 III but can not use it on the 70-300L so I am unsure of its performance but I can tell you it is by far a superior lens paired with canon lenses ment for its use. Jeff ........, 7D, 70-300L, 100-400LII
TeamSpeed 01010100 01010011 More info | Nov 07, 2014 06:21 | #14 Pondrader wrote in post #17257322 I can tell you the mark II makes the kenko 1.4 feel almost invisible compaired to the 7d, I had all kinds of focus issues but they are gone with the 7d mark II, I still prefer not to use it but it works so much better on the 7d2 Wow, that is strange. Did you try to MFA your lens and TC combo? You should really do that if not. The cameras will register a TC+lens as a different slot than just the lens as long as the TC reports back. Past Equipment | My Personal Gallery
Pondrader "now I'm no rocket scientist but I do get a shot or two" 16,028 posts Gallery: 2548 photos Best ofs: 5 Likes: 57084 Joined Aug 2012 Location: Minden, Ontario, Canada More info | Nov 07, 2014 06:47 | #15 I was using the kenko on a 70-300L , I do think it was the combo of the two, if I took it out to 420mm it would hunt real bad but at 380mm it was just ok. I found I could lock and Len zoom in to get the shot, not the best but the 7D mark II has solved the problem. Jeff ........, 7D, 70-300L, 100-400LII
| Latest registered member is ANebinger 1242 guests, 151 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
