Thread started 06 Nov 2014 (Thursday) 11:26
Night photography (layers of black)
tristan
Joined Feb 2006
Nov 06, 2014 11:26 |  #1
Hi people,
I have recently been shooting more night photograps of a local bridge. Thus far I have some pretty good images I would like to print. HOWEVER, is there a way to get rid of "layers" that occur when editing the image? I could provide an image here but compressing it will only make it look horrific. I'm not talking about adding layers in photoshop I'm talking about the layers of black to grey whenever brightening the image.
tristan
Joined Feb 2006
Nov 06, 2014 11:29 |  #2
Here is a crappy web image of it but you can see the layers I'm talking about.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/11/1/LQ_698976.jpg
Image hosted by forum (698976) © tristan [SHARE LINK]
tristan
Joined Feb 2006
Nov 06, 2014 11:30 |  #3
Maybe this one is better?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/11/1/LQ_698977.jpg
Image hosted by forum (698977) © tristan [SHARE LINK]
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Nov 06, 2014 11:33 |  #4
Try to describe the problem in different terms as layers of black isnt a technical term nor does it describe a problem. Be as descriptive as possible.
M_Six
Gallery: 68 photos
Nov 06, 2014 11:41 |  #5
I think tristan is referring to posterization. The lack of a smooth gradient from gray to black.
If that is the case, tristan, it may be your monitor that is causing it. I only have a tablet to view your image now, but it looks fine to me.
Mark J.
Gear
Eyeball2
Joined Jun 2014
Nov 06, 2014 11:41 |  #6
I can't see it very well in what you posted but I assume it is what we normally call "banding" or "posterization".
This can have several causes:
First, it can happen on your monitor. Most monitors only have 256 tonal values in a B&W image from black to white. That's not many when you are viewing a smooth gradient on a large monitor. Monitor quality and how well it has been calibrated and profiled can also impact visibility of monitor banding. The good news is if it's monitor banding, the actual image may be just fine. Others may see it OK and if you print, it may not be visible at all.
Second, this can happen in the actual image if you are pulling up the brightness of shadows. In the raw file, there are much fewer tonal levels recorded for dark tones than for light ones. You can read a little about that here:
http://www.luminous-landscape.com/tutorial​s/expose-right.shtml (external link)
ETTR won't help you here, since you are already clipping highlights, but here are some things you can try to do to reduce the banding if it is occurring in the actual image:
- Make sure you are working in 16-bits until the last possible moment. Saving a final 8-bit Jpeg is fine but you want to be in 16-bits up until then.
- You can try to add a very little bit of fine, monochromatic noise to the image. As counter-intuitive as that sounds it often works since it "breaks up" the solid bands and makes them harder to notice. Some people try to blur the bands but this usually makes them worse.
Hope that helps.
tristan
Joined Feb 2006
Nov 06, 2014 11:44 |  #7
I don't know the technical term hence the poor description... When lightening the photo you see layers stacked on top of one another going from lighter shade to lighter shade. Here is an attached photo of an exaggerated example. Thanks.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/11/1/LQ_698981.jpg
Image hosted by forum (698981) © tristan [SHARE LINK]
Christopher ­ Steven ­ b
Nov 06, 2014 22:42 |  #8
Did you process this in 8-bits at any point ? That's normally what leads to this problem. Regardless, if the posterization is in the image and can't be rectified by altering your process (particularly if you're messing with curves), adding a bit of noise can help.
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
armis
Joined Jan 2012
Nov 07, 2014 05:03 |  #9
Like others have said, try adding noise. Also, I believe files react better to adjusting exposure in color and then converting to B&W, rather than starting with B&W and then boosting shadows. Maybe try doing things this way around.
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
kirkt
Nov 07, 2014 12:09 |  #10
Can you describe your workflow to produce these images?
kirk
Kirk
2,415 views & 0 likes for this thread, 7 members have posted to it.
493 guests, 124 members online
