I have a photo with a Magenta color cast on a specific area that cannot be removed properly with Hue/Saturation and a mask. Is there a way to de-saturate it, and only it(maybe by selecting it somehow)?
TIA
rfe777 Member 81 posts Likes: 1 Joined Sep 2012 Location: Israel More info | Nov 09, 2014 15:55 | #1 I have a photo with a Magenta color cast on a specific area that cannot be removed properly with Hue/Saturation and a mask. Is there a way to de-saturate it, and only it(maybe by selecting it somehow)? Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
gonzogolf dumb remark memorialized More info | Nov 09, 2014 16:02 | #2 Using the selection tool you can select a color range, once selected you could then manipulate it. Just do it on a new layer that you can mask back in so that you dont have to worry that simikar tones elsewhere in the image are affected.
Nov 09, 2014 16:06 | #3 gonzogolf wrote in post #17261564 Using the selection tool you can select a color range, once selected you could then manipulate it. Just do it on a new layer that you can mask back in so that you dont have to worry that simikar tones elsewhere in the image are affected. How can you select a color range? you use the selection tools to select an area. Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
gonzogolf dumb remark memorialized More info | Nov 09, 2014 16:07 | #4 rfe777 wrote in post #17261574 How can you select a color range? you use the selection tools to select an area. What version of ps?
Nov 09, 2014 16:23 | #5 gonzogolf wrote in post #17261576 What version of ps? Photoshop cc 2014 Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
gonzogolf dumb remark memorialized More info | Nov 09, 2014 16:26 | #6 I only have cs 3 but using the selection menu there is tool for selecting color range. Eyedropper tool to select the troubling color then adjust the fuzziness to expand or restict the selected range. Then adjust saturatin as desired.
Eyeball2 Member 132 posts Likes: 3 Joined Jun 2014 More info | Nov 09, 2014 16:37 | #7 Select>Color Range from the menu.
Nov 09, 2014 16:41 | #8 gonzogolf wrote in post #17261598 I only have cs 3 but using the selection menu there is tool for selecting color range. Eyedropper tool to select the troubling color then adjust the fuzziness to expand or restict the selected range. Then adjust saturatin as desired. How can it be done with adjustments layers? Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
gonzogolf dumb remark memorialized More info | Nov 09, 2014 16:43 | #9 Sorry if you cant follow the instructions above I cant help you. Its not that hard.
Nov 09, 2014 16:44 | #10 gonzogolf wrote in post #17261627 Sorry if you cant follow the instructions above I cant help you. Its not that hard. Please read again what I wrote. Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
gonzogolf dumb remark memorialized More info | Nov 09, 2014 16:48 | #11 rfe777 wrote in post #17261628 Please read again what I wrote. And please try what I suggested. Once you have the range selected use sny of the color manipulation tools you wish.
Nov 09, 2014 17:02 | #12 gonzogolf wrote in post #17261633 And please try what I suggested. Once you have the range selected use sny of the color manipulation tools you wish. I have tried what you suggested, but I always use adjustments layers to do my color corrections and not the options that are in the menus, as they(adjustments layers) are non-destructive and can always be deleted or changed as needed. So how can your technique be done in adjustments layers? Sony A6000, Sony Vario-Tessar T* E 16-70mm f/4 ZA OSS, Sony 35mm f/1.8 OSS , Sigma 19mm f/2.8 DN
Nov 09, 2014 17:42 | #13 Just create a new layer and select an area to work in. That's about as non destructive as it gets. Fujifilm cameras and lenses.
gonzogolf dumb remark memorialized More info | Nov 09, 2014 17:49 | #14 rfe777 wrote in post #17261652 I have tried what you suggested, but I always use adjustments layers to do my color corrections and not the options that are in the menus, as they(adjustments layers) are non-destructive and can always be deleted or changed as needed. So how can your technique be done in adjustments layers? Make a new duplicate layer.
M_Six Cream of the Crop More info | Nov 09, 2014 18:48 | #15 If the area with the color cast is small, just draw a selection box around it and hit Ctrl-J (or Cmd-J on a Mac) to put the area on its own layer. Then bring up the ACR filter (CTRL-Shift-A or Cmd-Shift-A on Mac). Go to the the lens correction tab and check Remove Chromatic Aberration, then move the purple sliders and see if they won't fade out the color cast. Mark J.
| Latest registered member is ealarcon 1114 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
