WithJustAClick wrote in post #17265243
I have just purchased a 7d and intend to use my 24-105mm f4L on it for a walk around lens, which leaves a hole on my 5dii.
My main interests are landscape and portraits and a bit of street photography and I am a little drawn towards the 17-40mm f4 L mainly for the FF.
I have done my homework and read many reviews and can pick up a decent lens for around the £400.00 mark, which is about the amount I wish to spend, but there seems to be a lot of negativity around it, since the 16-35mm f2.8 L appeared.
I know all about the 2.8 against the f4 situation and it's a quite old design lens, but apart from the corner softness, at that price is it really that bad?
So my question is really, will the 17-40mm be that much of a let down if I purchase one in comparison to the 24-105mm.
Heya,
I like the 17-40 more than the 24-105. The 17-40 is one of the few L-zooms that I would buy since it's commonly had for $500 these days, takes filters, is ultrawide, great color & contrast, has some weather sealing, and is pretty sharp. Is it distorted in the corners at it's wider focal lengths? Yes, all ultrawides have distortion. Does it get soft in the corners compared to it's center, a little yes, but it's not stopping people from using it to the point of throwing your hands in the air (look in the sample thread, the last thing you look for is a soft corner). F4 doesn't matter to me here, as I would be stopping down to F8 most likely or more. Will you miss F2.8 over F4? That's up to you. The 16-35 doesn't perform great at F2.8. It's noticeably not great at F2.8, which to me, for a $1k lens is not acceptable. It sharpens up when you stop it down. Well, in that case, it's really not a F2.8 lens for most use unless you're shooting the sky (in which case, save your money, get a Rokinon 14 F2.8 or something instead for that purpose). So the 17-40 wins in my book.
What wins harder than the 17-40, by being better priced and optically about as good, is the Tamron 17-35 (my opinion only).
Very best,
