Thread started 14 Nov 2014 (Friday) 03:08
7D II Flicker setting question(s)
StarJack
Nov 14, 2014 03:08 |  #1
Hi, for those of you that have a 7D II, have you tried the anti-flicker mode under fluorescent (or sodium vapor) lights? How has it worked for you? Interested in hearing any specifics you can provide. I occasionally shoot indoors in halls or auditoriums that may have many fluorescent lights, or a few in combination with incandescent, LED, or natural light. These situations can be very tedious to try and correct in post. I'd like to hear opinions (good or bad) of anyone whose tried the camera under those difficult mixed lighting scenarios.
Regards,
Steve
Eccentric ­ M
Nov 14, 2014 05:56 |  #2
http://www.the-digital-picture.com …News-Post.aspx?News=13866 (external link)
EOS 7D - EF-S 15-85 IS USM - EF 50 1.8 II - EF 70-300 IS USM - Speedlite 430EX II
A6000 - 16-50 PZ OSS
John ­ from ­ PA
Joined May 2003
Nov 14, 2014 13:03 |  #3
Although I typically shoot landscapes I find this to be interesting technology!
Tom_D
Nov 14, 2014 13:41 |  #4
I've seen the flicker icon come up while pointing the camera around inside the hose. I moved the setting to my menu to be able to get to it quickly when needed.
It was also mentioned here.
Gallery (external link)
7DMkII, 40D, 17-55, 70-200 f/2.8 IS and more...
More Wag, Less Bark
Keyan
Joined Mar 2011
Nov 14, 2014 13:57 |  #5
It does occasionally come on when there aren't any flickering lights. I also think some LED backlights from TVs can set it off as they often pulse at different speeds to adjust the main backlight brightness level dynamically.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
rrblint
Gallery: 84 photos
Joined May 2012
Nov 14, 2014 14:02 as a reply to  @ Tom_D's post |  #6
Very cool indeed.
Mark
eigga
Nov 14, 2014 14:46 |  #7
Most of my "flicker" issues involve multiple lights cycling at different times. Is it really able to fix that?
-Matt
Website (external link)
Facebook (external link)
Instagram (external link)
Tom_D
Nov 14, 2014 14:57 |  #8
eigga wrote in post #17272129 (external link)
My understanding of the issue is the alternating power source of the lights, and if all the lights are on the same 60Hz source shouldn't the "flicker" rate all be the same?
More Wag, Less Bark
apersson850
Obviously it's a good thing
Gallery: 35 photos
Nov 14, 2014 18:05 as a reply to  @ Tom_D's post |  #9
The rate would be the same, but in areas of the world where the electrical system is reasonably developed, it's common practice to connect lights in large buildings to three-phase supplies. This is to even out the load on the three phases. Thus approximately 1/3 of the lights flicker at 50 Hz rate (100 times per second), the next 1/3 also at 50 Hz and the same for the last 1/3. But their phase is 120 degrees apart, so the total flicker will be less, but will show peaks corresponding to 150 Hz, or 300 peaks/s.
Thus the flicker effect would be far less, and perhaps not detectable by the camera, had the light sources been interleaved. But often the 1/3 that runs from L1 are at one side of the building, those on L2 in the middle and those on L3 at the other side. Thus you'll have the normal flicker effect everywhere, but the camera can't fix more than one area of it at a time.
Anders
Tom_D
Nov 14, 2014 18:17 |  #10
apersson850 wrote in post #17272448 (external link)
Thanks. I wasn't thinking a 3 phase panel. I guess we would have the same issues here but at 60Hz. I'll pay attention to that and the flicker indicator the next time I'm in a commercial building with the 7D2.
More Wag, Less Bark
eigga
Nov 14, 2014 21:51 |  #11
All that is above my head but I can tell you at the gyms and football fields I cover they cycle at different times. I often have images with lights cycling at different times and thus the image is split on exposure and white balance.
-Matt
rrblint
Gallery: 84 photos
Joined May 2012
Nov 14, 2014 22:03 |  #12
eigga wrote in post #17272739 (external link)
...the image is split on exposure and white balance.
This happens even when they are cycling at the same rate and time.
Mark
eigga
Nov 14, 2014 22:18 |  #13
Anyone have real world examples of this feature working? I don't need basement light samples. I need a high school gym or middle school football field :)
rrblint wrote in post #17272761 (external link)
-Matt
apersson850
Gallery: 35 photos
Nov 15, 2014 02:36 |  #14
Tom_D wrote in post #17272461 (external link)
If you by "we" mean the US in general, then it's not for certain. The US power supply system lacks quite a lot compared to continental Europe. Here we had the "advantage" of the different existing systems being badly damaged by 1945, so when they were rebuilt, the design was based on experience dating back to the late 1800's. Thus many of the mistakes and bad decisions which still paluge the US system were removed and replaced with a better design in Europe. The 230/400 V 3N~ is clearly superior to the common US distribution system, and also lends itself much better to even load distribution in the way I described above.
As you perhaps understand electrical stuff is my profession, but I don't have the same detailed knowledge about how this is solved in the US.
Anders
russbecker
Gallery: 61 photos
Nov 15, 2014 05:43 |  #15
I can comment on the anti-flicker mode. I have been evaluating a 7D2 for the past week, comparing its performance in a variety of situations with the 7D I have used for 5 years. One of the shooting situations I have tested is dimly lit gyms with bad discharge lighting.
Both cameras are used in manual mode. With the 7D typically 25 per cent of the shots would be underexposed by 1 to 1.5 f-stops, 25 per cent overexposed by an f-stop, and the other 50 per cent would be about right. With the 7D2 in anti-flicker mode, all of the shots have the same exposure, so the anti-flicker feature works as advertised.
In addition, the 7D2 is about 1/3 f-stop more sensitive at equivalent settings ( f/2.8, 1/200, ISO-6400) than the 7D; i.e. the 7D2 images are about 1/3 f-stop brighter -- this is in RAW.
7D2 | 80D | Fuji X-H1 | Fuji GFX100S | 100-400 f/4-5.6 IIL | 300 f/4 L | 70-200 f/2.8 IIL | 135 f/2 L | 85 f/1.8 | 100 f/2 | 60 f/2.8 macro | nifty-fifty | 10-22 f/3.5-4.5 | Fuji XF 100-400 f/4.5-5.6 | Fuji GF 50mm f/3.5 | Sigma 30 f/1.4 | Neewer X 25mm f/1.8 | Neewer X 32mm f/1.6
5,417 views & 0 likes for this thread, 10 members have posted to it and it is followed by 3 members.
1065 guests, 115 members online
