Thread started 16 Nov 2014 (Sunday) 09:24
7D Mk II - overexposure with 2x TCs
Keith ­ R
Nov 16, 2014 09:24 |  #1
Initially just canvassing opinion/putting it out there...
So far I've been delighted with my 7D Mk II - it improves over my 7D and 70D in every area that matters to me.
Except...
Whereas those cameras both work perfectly well with my Sigma 120-300mm f/2.8 and 70-200mm f/2.8 lenses, and 2x TCs (Sigma or Canon Mk II), my 7D mk II over-exposes by almost two stops with the same lens/TC combos.
Every time.
In any exposure mode.
1.4x TCs from Canon, Sigma and Kenko all work perfectly with my 7D Mk II and the Sigma lenses; but with either 2x, exposure is all to hell.
I can get round this easily enough by dialing in -1.75 EC, but it's a 100% repeatable problem, so presumably fixable via a firmware update, assuming that it's not a freaky by-product of the specific combinations of camera, lenses and TCs I'm using.
Anyone else seeing this?
apersson850
Gallery: 35 photos
Nov 16, 2014 09:53 |  #2
Does it happen with Sigma lenses mounted on the converter only, or also with Canon lenses?
Anders
Keith ­ R
Nov 16, 2014 10:03 |  #3
apersson850 wrote in post #17274986 (external link)
So far I've only been able to test with Sigmas - it'll be a week before I can put a suitable Canon (a 70-200mm f/2.8 II) on.
robert614
Gallery: 32 photos
Joined Jul 2013
Nov 16, 2014 11:03 as a reply to  @ Keith R's post |  #4
I just tried out my 70-200mm f2.8 II w/2x III extender and exposure looks normal.
Sounds like maybe Sigma needs to issue a firmware update perhaps.
One thing,which I'm sure you're aware of,is the order you mount the extender.Canon states you should first attach the extender to the lens,then attach both to the camera body.This is to insure proper communication between the lens and body.
I'm sure you already do this,but I mention it just to make sure.
Good luck finding a solution,
Robert
Keith ­ R
Nov 16, 2014 11:46 |  #5
Thanks Robert, very helpful.
As you suggest, I've a feeling I might end up pushing this Sigma's way, and you've helped narrow things down.
Although I'm not sure that the connection order of the components matters as much for third party lenses and TCs (Canon's guidance here seems very specific to the Mk III TCs) I've borne it in mind anyway, but it hasn't made a difference, I'm afraid.
This isn't a show-stopper for me - I don't use 600mm that much really - and the -ve EC workaround works well enough.
Thanks again.
artyman
Sleepless in Hampshire
Gallery: 17 photos
Nov 16, 2014 12:01 |  #6
This could be a problem for me then as I use 2X extensively with my Sigma 120-300 for birds, so perhaps I should defer my 7D2 purchasing decision.
Ken
apersson850
Gallery: 35 photos
Nov 16, 2014 12:31 as a reply to  @ artyman's post |  #7
Nah, treat yourself to the new EF 100-400 mm f/4.5-5.6L IS II USM, and it's likely that any Sigma-related problems go away!
Anders
Keith ­ R
Nov 16, 2014 13:12 |  #8
artyman wrote in post #17275185 (external link)
As I suggest, it's manageable easily enough by dialing in some -ve EC, but it's a pain. In all other respects, the camera's brilliant.
And if it is something that Sigma needs to address, you're not really gaining anything by holding off on the camera.
LJ3Jim
Joined Jan 2012
Nov 16, 2014 13:56 as a reply to  @ Keith R's post |  #9
Just tried my 7D2 plus 2x tc III with my Canon 300 2.8 II and my Canon 70-200 f/4 IS. I didn't have any exposure issues.
Regards, Jim
Image editing ok; C&C always welcome.
Keith ­ R
Nov 16, 2014 14:26 |  #10
Thanks Jim - pretty clear it's a Siggy thing, then.
That said - both you and Robert have used the Mk III Canon 2x: I wonder if that's making a difference (mine is the Mk II)..?
gabebalazs
Bird Whisperer
Gallery: 52 photos
Nov 16, 2014 20:45 |  #11
somebody throw me a 7D2 quickly..., I'll test your problem ;)
I have the same setup as you do Keith, minus the 7D2. I have no problem with it on my 70D.
SONY A7RIII | SONY A7III | SONY RX10 IV | SONY RX100 | 24-70 2.8 GM | 70-200 2.8 GM | 16-35 F/4 | PZ 18-105 F/4 | FE 85 1.8 | FE 28-70 | SIGMA 35 1.4 ART | SIGMA 150-600 C | ROKINON 14 2.8
Gabe Balazs Photo (external link)
Nature Shots Portfolio (external link)
Keith ­ R
Nov 17, 2014 00:45 |  #12
Yeah, the lenses and TCs are fine on my 70D too, Gabe...
Keith ­ R
Nov 17, 2014 11:23 |  #13
Nobody else shooting with a 7D Mk II, 2x TC and third party lenses, then?
exerda
Nov 17, 2014 12:03 as a reply to  @ Keith R's post |  #14
I've had no problems with the 300f4 or the 500f4 II using the 2x III. Sorry, none of those are 3rd party, but as far as with those particular pieces of equipment, I've had no exposure issues.
Canon 6D; 7D mkII; EF 500mm f4L II; EF 24-105mm f4L; EF 300mm f4L IS; EF 16-35 f2.8L II; EF 24-70 f2.8L II; EF-S 10-22mm f3.5-4.5;1.4x TC III; 2x TC III Speedlite 580 EX II
Capn ­ Jack
Gallery: 2961 photos
Nov 17, 2014 19:53 |  #15
Keith R wrote in post #17277253 (external link)
No, but I got this response from Sigma today when I asked about using a 50-500 IS and my sigma 1.4 teleconvertor :
Hello Jack,
No it will not, the converter will prevent it.
Yours Truly,
Paul Pizzano
The Sigma Corp. of America
I'm still trying to understand that...
11,721 views & 0 likes for this thread, 15 members have posted to it.
650 guests, 124 members online
