My lens shoots a front focus image. I confused on which way to adjust, + or - in the AF Micro Adjustments.
Thanks for the assistance in advance.
Nov 17, 2014 22:49 | #1 My lens shoots a front focus image. I confused on which way to adjust, + or - in the AF Micro Adjustments. 7Dii gripped, 7D gripped, 5D gripped, 50D gripped, T90, Sigma 8mm Fisheye, Sigma 24-60 2.8, 70-200mm L 2.8, 400 5.6 L, 580 EX II, numerous filters, Monfrotto Tripod and Monopod.
richi914 Member 122 posts Joined Sep 2012 Location: PR More info | Nov 17, 2014 23:10 | #2 + 5D mark iii, 7d, sigma 28 f1.8, 50 f1.4, canon 100 2.8, 24-105 f/4, 17-40 f4, 300mm f4, 400 f5.6, 1.4 and 2xiii teleconverter, kenko 12/24/36 extension tubes, 430exii
Snydremark my very own Lightrules moment More info | Nov 17, 2014 23:59 | #3 SS308 wrote in post #17278646 My lens shoots a front focus image. I confused on which way to adjust, + or - in the AF Micro Adjustments. ![]() Thanks for the assistance in advance. If your lens is front focusing, you would have to adjust it back toward the camers. If you take a look at the LCD in the MFA menu, you'll notice that the graph shows a camera at one end [negative end] and a mountain at the other end [positive end] to make it easier to tell which direction you need to go. - Eric S.: My Birds/Wildlife
apersson850 Obviously it's a good thing More info | If it's front focusing, then it's already backed up towards the camera. It needs to focus further away from the camera. Anders
Nov 18, 2014 07:17 | #5 Snydremark wrote in post #17278706 If your lens is front focusing, you would have to adjust it back toward the camers. If you take a look at the LCD in the MFA menu, you'll notice that the graph shows a camera at one end [negative end] and a mountain at the other end [positive end] to make it easier to tell which direction you need to go. What? No, front focusing means the focal plane is in FRONT of the target, as in, too close to the camera. You need to PUSH it out away from the camera with positive (+) adjustments to get the focal plane to be on the subject. Cameras: 7D2, S100
Snydremark my very own Lightrules moment More info | Nov 18, 2014 09:31 | #6 Keyan wrote in post #17279055 What? No, front focusing means the focal plane is in FRONT of the target, as in, too close to the camera. You need to PUSH it out away from the camera with positive (+) adjustments to get the focal plane to be on the subject. Yeah; listen to Keyan...I'm moving in reverse apparently - Eric S.: My Birds/Wildlife
Thanks to everyone. I glad to see that I was not the only one confused on which way to adjust... 7Dii gripped, 7D gripped, 5D gripped, 50D gripped, T90, Sigma 8mm Fisheye, Sigma 24-60 2.8, 70-200mm L 2.8, 400 5.6 L, 580 EX II, numerous filters, Monfrotto Tripod and Monopod.
Nov 18, 2014 15:15 | #8 Which lens needs adjustment? Life is for living, cameras are to capture it (one day I will learn how!).
BodyResults Member 124 posts Likes: 7 Joined Sep 2010 Location: Seattle More info | Nov 18, 2014 15:43 | #9 The Dot Tune method of AF adjustment is a nice option for many. Fairly simple and no cost. Take a look at the video explaining the process:
Ralpho Member 161 posts Likes: 3 Joined Aug 2005 Location: St. Louis, Michigan More info | Nov 19, 2014 05:25 | #10 Snydremark wrote in post #17278706 If your lens is front focusing, you would have to adjust it back toward the camers. If you take a look at the LCD in the MFA menu, you'll notice that the graph shows a camera at one end [negative end] and a mountain at the other end [positive end] to make it easier to tell which direction you need to go. What is the MFA menu?
apersson850 Obviously it's a good thing More info | Micro Focus Adjustment menu. Anders
Ralpho Member 161 posts Likes: 3 Joined Aug 2005 Location: St. Louis, Michigan More info | Nov 19, 2014 07:52 | #12 apersson850 wrote in post #17280923 Micro Focus Adjustment menu. Thanks for the help. I had been looking for this adjustment without success. Cameras today are too complicated.
apersson850 Obviously it's a good thing More info | No. The setting you found on one camera is for that lens and camera in combination. The same lens on a different camera may give a different result. Anders
LibertyToad Member 120 posts Joined Oct 2009 More info | Nov 28, 2014 12:20 | #14 BodyResults wrote in post #17279979 The Dot Tune method of AF adjustment is a nice option for many. Fairly simple and no cost. Take a look at the video explaining the process: http://www.youtube.com/watch?v=7zE50jCUPhM The Dot Tune technique works quite well--I've had great luck with it. Another option is to download Magic Lantern for the 7D and install it. Then go into Magic Lantern and enable the Dot Tune module. This module will run the Dot-Tune process automatically. I had better results using the module than doing it without the module. Be sure to do it multiple times to make sure you get the correct MFA adjustment amount. I had to run it 3 times on each lens and pick the most consistent setting. Canon 7D, 17-85mm USM IS, 70-300mm USM IS, 24-105mm f/4 USM IS L, 35mm f/2
gonzogolf dumb remark memorialized More info | Nov 28, 2014 12:24 | #15 johnf3f wrote in post #17279932 Which lens needs adjustment? I only ask because I have yet to have a Canon Film/Digital SLR or Canon lens that needed to be adjusted. Just curious. You are a lucky man. My 85 1.8 was okay but once I did the micro adjust I found it performed much better.
| Latest registered member is semonsters 1046 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
